| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#76 | ||
![]() Join Date: Apr 2003
I hate when people say ''my car is faster than yours'' just shut the hell up |
#77 | |
just to back up what i have, my best mph so far is a 100.2 BTW:
with: Stock MAF Stock Cam Stock Heads Ported Plenum Centerforce Dual Friction Poly Tranny Mount Poly Torque Arm Mount Stock 3.08 Gears Modified Air Box K&N Filters Dynomax Headers Dynomax Cat Back Exhaust Hollowed Cat Delete Throttle Body Coolant Bypass IAT Sensor Relocated Emissions Delete AC Delete Stock Timing Rear Seats, Spare & Jack Removed For Racing
89 ROC - 305 TPI 5 SPD - 13.9 @ 97.08
#78 | ||
#79 | |
I didn't say you were full of BS, I just hate when people say that kinda stuff.
I bet that clutch really shave your time down eh? They help a lot. |
#80 | ||
Stang Guy
By the way you understand very lil about engines and stroker motors.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
#81 | ||
#82 | ||
I used to have a 383 stroker in my work truck that pushed approx. 425 HP and 450 ft/lbs. It did the 1/4 in 12.6 @114, it has 4.10 gears too. Needles to say the engine didn't need to ''wind up'' before it shot you like a bullet the instant you depress the pedal. |
#83 | ||
Anyone know why one way would be better/worse than the other? |
#84 | ||
Stang Guy
Here is the truth if you have two physically identical blocks, heads and intakes etc.., The only difference is one uses more bore to get 305 CU and one use more stroke to get 305CU. The engine with more bore will make more torque because piston surface area is more deciding factor on torque.
#85 | ||
#86 | ||
I plugged everything into my desktop dyno, everything the EXACT same except bore and stroke. The one was factory bore and stroke of a 305-3.735X3.48. The other I made 4'' bore and 3.034'' stroke. The factory 305 make 1 more HP and 2 more ft/lbs at 2K RPM. But the 4'' bore made 6 more peak HP and 2 more peak ft/lbs. Low end power is what a longer stroke is for, high end goes to shorter stroke engines. |
#87 | ||
Stanger
Source one; 83 Camaro 305, 190 bhp at 4800 rpms, with 240 lbs-ft at 3200 rpms. 83 Mustang 302, 175 bhp at 4000 rpms, with 245 lbs-ft at 2400 rpms. Source two; 91 Z28 305, 205 hp at 4200 rpms, with 285 lbs-ft at 3200 rpms. 91 Mustang 302, 225 hp at 4200 rpms, with 300 lbs-ft at 3200 rpms. Actually if you go to this site http://www.phy.duke.edu/~hartley/iroc/iroc_specs.html, and look at the torque for all the 305's, then reference the 302, you will see that the 305 in some cases makes the same amount of torque, and the rest of the time makes less torque then the 302. Now I still feel that the 305's long stroke and small bore is a big disadvantage compared to the 302's shorter stroke and bigger bore. That should make the 302 rev quicker cause it's pistons has less area to travel in the cylinder bore, making power quicker. Also just a side note. I never refereed to stroker motors, or anything other then the 302 vs. the 305. These motors have a similar displacement in common, whereas stroking a motor will increase the displacement making for more torque and hp. Not to mention, that most, not all, but most stroker motors have been bored to compliment the longer stroke for more cubes. 1BAD305, I'm sorry if you thought that you ruffled my feathers, but that could be farther from the truth. you came here with an attitude, so expect some hostility back, it's just natural when debates get heated. Also if you had taken the time to read my site, you would have known that my 60 ft times were horrible due to the lack of traction, and that is the main reason why I only went 13.8 at 101 mph. not to mention that my motor combo was still new to me and I was still feeling things out and how to drive the car properly. One last thing, I never said you were lying about your track times. I just said your mph seemed slow, and then asked what elevation you were running at? Cause you know, different elevations will effect what your car runs.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 Last edited by HiFlow5 0; 08-04-2003 at 02:36 PM. |
#88 | ||
4.030 bore x 3.75" stroke, OR, 4.000 bore x 4" stroke???? I don't hear of too many people who simply stroke it to 383 cid. |
#89 | ||
Stang Guy
#90 | ||
