Old 04-03-2004, 03:03 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Re: HOW TO.....Use Rubbing Compound And Polishing A Body
Originally Posted by StephenDeli
Is it essential to sand the body before polishing?
No not exactly. Its reccomended. But sometimes you will end up cutting through the paint with the sanding and then rubbing compound. I have achieved a mirror finish with just rubbing compound.
-Mike
Old 04-03-2004, 06:05 PM
pflau's Avatar
pflau pflau is offline
sanding, clearcoat, rubbing, wax!
Current project:
Ferrari 360 Spider Testarossa, F40
Porsche 959
Fujimi Lamborghini Countach LP500S Enthusiast Model (no end to that!)
Old 04-03-2004, 08:42 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
I paint, clear, sand, compound and wax. For me it's easier to have a steady hand at sanding than clearcoating perfectly and having to sand again.
nightmaR3Z
Old 04-03-2004, 10:29 PM
carlisimo carlisimo is offline
Send a message via AIM to carlisimo
I know a lot of people paint, then clearcoat, then polish.
Question about that... if your paint coat has moderate orange peel, and then you clearcoat and polish, will the orange peel still be visible through what's left of the clearcoat?
Old 04-05-2004, 10:53 PM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
If you sand after u paint and before you polish, won't dat scratch up the paint pretty bad, even with ultra high grit sandpaper? just somethin gi thought about.
Current Project:
Fujimi Veilside Combat Silvia S14...almost finished
Old 04-06-2004, 09:06 AM
mike@af's Avatar
Somewhat.
On real cars after I paint the basecoat and right before the clear coat, I wetsand the whole car with 2000grit. If you wetsand to much in one spot you'll go through to the primer, same with sanding to hard. After the tedious task is complete the whole car will look like a matte paint. Then the clear coat brings back an incredible shine, and polish.
Models are very similar to real cars.
-Mike
Old 05-16-2004, 10:21 AM
m.c model master m m.c model master m is offline
i dont get it wen you do it does it make the body cleaner
Old 05-16-2004, 12:26 PM
freakray freakray is offline
AF Modelrater
When you do what?
AF User Guidelines
Old 07-20-2004, 08:44 AM
Apexi_N1 Apexi_N1 is offline
Question: Can you polish over decal?
Old 07-20-2004, 11:57 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
why drag this old thread back up?! DO a search! This topic has been discussed SEVERAL TIMES!
Old 07-20-2004, 09:12 PM
Lownslow's Avatar
Lownslow Lownslow is offline
lloking sweet nice tutoria, too bad i skip this step but will keep it in mind when i dont
Old 08-14-2005, 07:41 PM
chato de shamrock chato de shamrock is offline
Hey primera thanks for the tip, its very helpfull.
I have a question for you or anyone who has tried the Tamiya rubbing compound products.
I just got back from a local hobby shop and found three different types of Tamiya rubbing compound. "fine" rubbing compound (blue/white box $4.00), "coarse" rubbing compound (red/white box $4.00), and "finish" rubbing compound (black/white box $8.00). I noticed this is the product you used, but which of the three rubbing compound did you use? Whats the difference between these three? The guys at the hobby shop couldnt answer that question. Is the "finish" rubbing compound pretty much the same as wax, is that why its called "finish"? Hope someone on here can help out.
A free plug in: www.houseofhobbies.com, in burbank, ca.
I'm new here. This is my first post. so pardon if my question may seem redundant, but i didnt see anyone ask about the differences in this product.
HEY!!! HEY!!!
Old 08-14-2005, 11:00 PM
ales's Avatar
ales ales is offline
Forza Schumacher
This tutorial was written at the time when tamiya only had one compound - it corresponds to the fine compound they have in their lineup now.
The difference between them is pretty much like you have with sandpaper grit - coarse to finer to the finest. In theory you'll need all 3 after you've sanded the paint to achieve the best result as the coarse one will remove scratches left by the sandpaper quicker but will not give quite the shine as it's, well, too coarse. The fine compound will remove the scratches left by the coarse compound and the finish compound will remove the scratches left by the fine compound.
Wax is a totally different thing; it's non-abrasive while all compounds are abrasive and is used to seal the shine you've achieved by the rubbing compound.
How to use tamiya compound Pippin1974 Car Modeling 9 04-11-2007 03:00 AM
Rubbing Compound & Polish help HittenSwitches Car Modeling 28 12-17-2005 07:52 PM
3M Automotive Rubbing Compound and Dupli-Color color-changing spray paint 3-pack CamaroSSBoy346 Car Modeling 12 07-14-2004 03:34 PM
Tamiya compound and polish in uk? jberry3 Car Modeling 4 04-15-2004 05:11 PM
How to Use Compound? RX7FD Car Modeling 3 01-12-2003 08:50 PM
