Old 07-04-2003, 10:22 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
3M Automotive Rubbing Compound and Dupli-Color color-changing spray paint 3-pack
I picked these up at walmart tonight. I just wanted to say that the 3M stuff works wonders on my models, but its a bitch to remove (its like a wax, rub on, wait 20 minutes, then rub off), and i just wanted to see if any ever used the dupli color color changing 3 pack (base paint, color changine paint, and clear). How is it?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-04-2003, 10:35 PM
cartuner's Avatar
cartuner cartuner is offline
Hey CamaroSSBoy346 i have used all the color changers from dupli color and they work great. but you need to use the dupli color primer under the base coat since the base coat "may" craze the plastic so doing this is the safe way to go about it. another thing to remember is the more coats of the color shifter paint the better and more radical the color shift. i used 12 light coats of the green/purple on my mr-s and i just bought the new color shifter to day it's called "ICE" and it is real nice and i can't wait to try it out.
Old 07-04-2003, 10:40 PM
cartuner's Avatar
Oh i forgot next time you go to wal-mart gets some of meguiars cleaner/wax that stuff is awesome and easy to use and you get a rich deep high gloss finish. just get a cotton cloth place a blob of cleaner/wax on it and start rubbing until it dries up and then wipe it off with a clean cotton rag. you will need to do this a few times ( 4 or 5) before you start getting the deep gloss shine. but it is worth it it's like looking into a mirror.
Old 07-04-2003, 10:45 PM
The car im doing this on is my BMW 535i. It was already primered, and painted. It was like this for a year. Then just tonight i sanded down the paint a bit then put the base coat on that.
Old 07-04-2003, 11:07 PM
cartuner's Avatar
What type of paint? enamel or laquer? if it's laquer then you will have no problems but if it is enamel then you may run into orange peel.
Old 07-05-2003, 12:57 AM
Thor302's Avatar
Thor302 Thor302 is offline
do you have any pics of that ice paint or a real car with it?? sounds sweet
Old 07-05-2003, 01:05 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
You'll run into orange peel with any kind of paint.
Old 07-05-2003, 01:16 AM
cartuner's Avatar
sorry thor302 no pictures since i haven't used the paint yet.
Old 07-05-2003, 10:06 AM
its laquer
Old 07-05-2003, 10:27 AM
Thor302's Avatar
ah fiddlesticks!!!
Old 07-14-2004, 10:03 AM
NeonAtron NeonAtron is offline
Re: 3M Automotive Rubbing Compound and Dupli-Color color-changing spray paint 3-pack
what do i do after i do the 3 steps after the clear coat? sand it then wax or polish?
Old 07-14-2004, 11:20 AM
Vric's Avatar
Vric Vric is offline
I used the duplicolor Mirage paint. Not on model but on computer Cases.
It's nice color, but the flake might be too big for model. It's easy to work with and give a good effect
Old 07-14-2004, 03:34 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
i have used the dupli-color , color shifting paint, the stuff is awesome!!,
also dupli-color is the only paint i use to paint my models , i highly recommend this brand
