Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-28-2005, 01:40 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: two questions
TFS Stage 2
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-28-2005, 05:25 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-28-2005, 05:53 PM
SkylineUSA's Avatar
Re: two questions
Originally Posted by GTStang
I know
Old 08-28-2005, 06:17 PM
Pimpdady753 Pimpdady753 is offline
Re: two questions
it does not come with that one,
Cam Kits - High Performance True Roller Timing Set with:
Custom Schneider Hardened Steel Billet Hydraulic or Solid Cam
Dyno-Designed for Stroker Applications. Add...... $275
Custom Schneider Hardened Steel Billet Roller Cam Dyno-Designed for Stroker
Applications. Add...... $349
is it hard to install a cam shaft.
Old 08-29-2005, 01:12 AM
SkylineUSA's Avatar
Re: two questions
How high do you want to spin it? I say go roller hydro, that is what I am using. Solids you have to adjust ever 1000 miles or so.
No, its easy to install a cam. Anything is easy if you have done enough times
If its a custom, you should be good to go.
Old 08-29-2005, 01:34 AM
Re: two questions
your saying the Hydraulic one that is 275
Old 08-29-2005, 01:44 AM
Re: two questions
see i dont know much about the cam shaft part of the engine or the lifts and the compresion riso. that is the only thing i dont know about in engines.
Old 08-29-2005, 05:26 PM
SkylineUSA's Avatar
Re: Re: two questions
Son, there is still a lot that I do not know about engines.
Old 08-29-2005, 06:28 PM
Silver Fox Silver Fox is offline
Re: Re: Re: two questions
I learn somethin new everyday!!!!!
Old 08-29-2005, 11:02 PM
Re: two questions
me to, what is the diference on Hydraulic and roller cam shaft.
Old 08-30-2005, 01:31 AM
GTStang's Avatar
Stang Guy
Ugh I can't believe I'm in here..... anyway....
Camshafts for Dummies:
Roller or Flat means what kinda lifters is it using, roller lifters or flat lifters. Flat lifters are just that flat metal bottoms against the cam lobes, rollers are again just that rollers along the cam lobes.
Hydrualic or Solid: Both Flat or Roller cams(lifters) can come in both of these forms. Hydrualic lifters use engine oil to in the simplest description of terms act as a shock absorber. Solid lifters wether roller or flat are just a solid roller with no hydraulics to dampen the valvetrain.
Notes:
Cams and lifters must match: Solid roller cam wit solid roller lifters. Flat hydraulic cam wit flat hydraulic lifters, etc..,
Blocks must match Cam: Block must come set-up from the factory for roller camshaft. If not your, options are to machine it for a roller camshaft set-up or use a retrofit set-up if available.
Applications: If someone else wants to even begin to open that can of worms go ahead.
Old 08-30-2005, 02:03 AM
boosted331 boosted331 is offline
If you go over 6500 rpms you need a solid.
He doesn't need a solid, it just starts to get beneficial at that point. A comp 282HR will hold onto power to about 7 grand at which point it will start to float the valves,
pimpdaddy: Maybe think about like a stock 302 with some flows and a CAI. Judging from the fact that all you want this car to do is "beat up ricers on the street" and considering you've never had a fast car before and sound quite immature, all you're going to do with a 1000 horsepower blown car is hurt/kill yourself or someone else. To give you an idea of just how much power 1000 HP is, imagine how long it takes for your 5.0 to get to 130 MPH. A 1000 HP fox will spin street tires like you're driving on ice to 130 MPH.
Old 08-30-2005, 02:04 AM
SkylineUSA's Avatar
Re: two questions
On my 69 block, I am running a set of Isky linked bar roller lifters, new they run $600 and that is at good price.
Since he is getting a package deal, the guys setting his engine up should know.
Old 08-30-2005, 02:11 AM
SkylineUSA's Avatar
Re: Re: Re: Re: two questions
Agreed, just telling him his options
Old 08-30-2005, 02:23 PM
That's not so bad, the Shubeck Roller-X's in a buddies turbo motor just set him back, get this, a grand. They eliminate any bearings inside the lifter and have it ride on a cushion of oil. They're supposed to be the best and eliminate lifter failure, so I sure hope so!
