Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-06-2003, 01:49 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Well, I was personally talking about the series 2 first gen RX7 with the 12A rotary. The 12A weighs something to the order of 350 lbs, which is only 70 lbs lighter than a Ford 5.0 smallblock, which can easily be built for 300hp for very little money, and 400hp for a bit more money. If you really know how to build the engine right, you can get 450hp on pump gas.
The engine and tranny will bolt in, the only actual modifications being denting the firewall slightly in a few places for clearance, a new transmission crossmember, and a shorter driveshaft to make up for the longer transmission.
Depending on the model you pick, this gives you a curb weight of between 2250-2350 lbs. There are numerous options for suspension and brake upgrades. In fact, the reason I recommend going for one of the widebody kits is the first gen body doesn't have enough room for the tires you would need with this sort of power. Provided you have the traction to make it happen, a 10 second run should be no problem with this car.
Also, by using a full competition IMSA body kit, you should be able to drop quite a few pounds, maybe getting it down to 2200lbs.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 01-06-2003, 01:58 PM
DemonZX's Avatar
DemonZX DemonZX is offline
Send a message via Yahoo to DemonZX
Oooooo...That kind of talk gives me chills!
R.I.P. "Mama (my Z)" . . . But now we have the VR-4 #683/2000
"Dude, You fucking passed the test, but just barely, wanna know what you got?...F+......CLICK!"
-Tenacious D(Jack BLack)-
"Official Moron Crew Founder!"
