| Latest | 0 Rplys |
#31 | |
![]() Join Date: Jan 2005
Re: Jimmy acceleration problems
should i return the cheap-arse plastic $16 distro cap too?
#32 | |
AF -Advisor
![]() Join Date: Sep 2003
All cap and rotors are plastic, no such thing as a metal cap and rotor other than the contacts.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#33 | |
A long days work has been fairly succesful.
Replaced: CPI unit Nut Kit Distributor Cap, rotor, wires & plugs. Fram Air Filter Also replaced EGR, TPS, and fuel filter a couple weeks ago. She sounds clean, BUT there seems to be a subtle knock, not loud, coming from EGR area, or maybe valve covers. not sure what to make of that. the EGR is mounted onto a thread that snapped, I just put a nut on it - but had to grind part of the EGR base down to get the nut onto the short thread sticking out. when i first put this on the EGR did not want to mount flush. i wonder if the knock is just air seeping from the EGR gasket, or something else. almost in over my head... thanks for all input! |
#34 | |
AF -Advisor
Oh god, this is not good.
Who knows but you should change your oil and your filter seeing your oil is probably full of gas from the CPI leaking.
#35 | |
My jimmy was doing the same thing, and it turned out to be the ECM under the distributor. One of the plug socket's was broke inside, sometime's it would run and other time's nuthin. The ECM has to deliver the right voltage to the fuel pump or it doesn't maintain enough pressure to run. The plug's in the back can break (the ECM itself) and cause fluctuation's, slow sluggish, stalls, and not starting.
#36 | ||
Re: Re: Jimmy acceleration problems
How much is this part if I was to replace it myself, I'm having similar problems, random stalling then no start for about an hour, then runs fine for another day... |
#37 | |
What was yours doing?
Anything like my problem? http://www.automotiveforums.com/vbul...96#post3321896 |
#38 | ||
My Injector ELectrical Connector does not fit tight onto the top two pins of the CPI...any creative solutions for that besides tape it tight on the outside? Or besides spending ??$$$$ on a new one... THe reason my EGR was knocking a while back was because it was not on completely tight - slight gap, it was just air rapping out of it. I'll spare the details.\ Thanks and good luck to all! |
#39 | |
AF -Advisor
The grime in the upper plenum will take several thousands of miles to come back.
What you are seeing is the washing from the last CPI blowing.
#40 | ||
You're quite helpful I should send you a xmas card or something! In August. cheers |
#41 | |
AF -Advisor
I looked down my plenum to check a month ago and I thought the same thing until I llooked at the photos I took before I replaced it and the same markings and washed areas were there from the last one.
