Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-11-2004, 03:38 AM
wagam99 wagam99 is offline
Send a message via Yahoo to wagam99
Re: clicking noises
Originally Posted by heather4671
there's been a recall........I got the letter a week ago. I think it's for 99-01, not certain though. Check into it. Also for anyone that had to pay for that problem out of pocket you can send the reciept in and get reimbursed.
Heather
hi I have a 99 grand am with the same problem ,how long ago did you get the notice? and do you know if it matters if you are not the original owner? thanks!
  #32
Old 02-05-2005, 07:12 AM
SammiPrincess SammiPrincess is offline
Question blinkers and emergency lights
Samantha
[color=mediumturquoise]Samantha[/COLSa mmi OR] Princess ISammi
  #33
Old 03-03-2005, 10:45 PM
meti meti is offline
Send a message via ICQ to meti Send a message via AIM to meti Send a message via MSN to meti Send a message via Yahoo to meti
Re: clicking noises
Originally Posted by road_rascal
My sister-in-law's 2001 Grand Am SE is doing the same thing- clicking non-stop but everything works. The recall does not apply to her car for some reason (built at a different time/plant maybe). Anyways, before I blindly start buying parts to fix it what does everyone think the main problem is- the hazard switch or the multifunction switch?
yeah i would suggest to replace the switch since the signals and everything works. I hav talked to a technicial and he suggested for me to change my switch which is a long piece of plastic behind the hazard light button above the stereo.
I have the same problem with random clicking and but turning signals work and when random clicking accurs the signals dont act with it. thanks god! haha
well the switch is coming from Ebay soon so I will have my car hopefully fixed
  #34
Old 03-05-2005, 03:09 PM
Re: clicking noises
OKAY! I replaced the hazard switch yesterday and the problem seems to be solved for me!
good luck!
  #35
Old 03-09-2005, 07:04 PM
r.hardin r.hardin is offline
Re: clicking noises
My 2002 grand am se1 is doing the same stupid thing it is going to make me crazy. Where was the multifunction switch found online?
  #36
Old 03-09-2005, 07:44 PM
Re: clicking noises
mine was from Ebay and but it didnt fix the problem 100% as i am experiencing some ticking noise but rarely!
I dont know what else to do by open the damn switch and try to clean it out! I am sorry but I am really just going to let professionals handle this for 100$ because I am sick of it and it drives me crazy!
try cleaning or i guess replacing it but i couldnt promise u anything
Good Luck!
  #37
Old 03-10-2005, 08:49 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: blinkers and emergency lights
Originally Posted by SammiPrincess
Samantha
Question - why the hell did you resserect such a damn old thread just to say "Samantha?" and that's been your only post? I don't get it.
Old 03-11-2005, 05:28 PM
Re: clicking noises
lol ;-)
  #39
Old 04-15-2005, 09:18 PM
mrlsle mrlsle is offline
multifunction switch recall
I had the switch replaced April 04 under recall and now I have the same problem again. I will return it to the dealer next week and let you know the result.
  #40
Old 04-15-2005, 11:04 PM
Ridenour's Avatar
GranddAmnit
Re: clicking noises
welcome to the forum mrlsle. Next time, please make a new thread instead of resserecting one that is over a month old / especially one that's this big. It helps keep the forum less cluttered.
Old 05-03-2005, 08:36 PM
beboetk beboetk is offline
Re: clicking noises
I just cleaned the contacts and the cable harnessand the mechanism on the multifunction switch and that solve the clicking problem.Just remove the three screwsin the botton of the steering wheel, loose the plastic cover, then remove the screw on the top and disconect the three conectors. Try to clean it with an electrical cleaner(can of spray if you can get one, it's not expensive.like 6 dlls at home depot). wait until it's dry and reinstall everything. It works. Don't forget to disconect the negative terminal of the battery, just in case of the deployment of the airbag and/or a short-circuit.
  #42
Old 08-16-2005, 05:18 PM
blablacent38 blablacent38 is offline
Send a message via AIM to blablacent38 Send a message via Yahoo to blablacent38
Re: Re: clicking noises
Originally Posted by Markgase2000
there was a recall on those switches so take your recipts to any pont/gm dealer and they WILL REIMBERSE you for the cost.
I had the same clicking problem as all of you.
I also fixed it by opening the turn signal switch and removing the grease between contacts.
  #43
Old 09-10-2005, 10:55 AM
cruehead2 cruehead2 is offline
I had the recall done for the hazards. It didnt fix the damn clicking. For now, I wedge a penny in between the flasher button and the frame around it. You won't be able to use you signals, so be careful.
  #44
Old 11-04-2005, 03:02 PM
99gadriver 99gadriver is offline
Originally Posted by zabut
I thought it was the switch in my car as well. But it turns out the fix is really simple. It is actually the turn indicator/lights mechanism around the steering wheel. (It is a somewhat large unit). Simply detatch it, you need to get the *special* star screwdriver (or an allen key might work) to open it up, but GM uses some crappy grease in there which I think eroded the contacts somehow, and mixed in with the grease making a faulty contact. I didn't believe it either, until i wiped up the grease, cleaned it with rubbing alchohol, and reinstalled it. Worked like a charm for an easy 20 minutes work. Sure beats the $150+ GM will charge you for a new unit. Also, the noise is coming from the hazard light switch (thats where the relay is), and would lead you to belive that is where the problem is (I tried to replace that unit to no avail), but the problem is actually around the steering wheel. BTW, I have a 2000 GrandAM SE.
Good luck!
Marc
This is exactly how I fixed the problem on my GA as well. I did it 2 years ago and no problems since.
  #45
Old 11-04-2005, 03:21 PM
Ridenour's Avatar
GranddAmnit
Re: clicking noises
Welcome to the forum. Please don't ressurect threads that are over a month old.
front clicking noise. wheel?? sohcd16 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-24-2010 08:53 PM
Clicking Noise in Motor - Please help! Jpb1970 General Discussion 4 04-28-2010 11:38 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
Closed Thread
