Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 05-03-2001, 11:00 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Oh yeah which brings up another point. Oil filters. Please tell me everyone here uses either the standard Nissan/Infiniti filter or a Mobil filter. They have a drain back valve standard and some of the cheeper brands *cough*fram*cough* don't, and that could effect the longevity of your motor. I know they cost more but please...it's your motor we're talking about.
Old 07-20-2001, 02:54 PM
primera2.0GT primera2.0GT is offline
Send a message via AIM to primera2.0GT Send a message via Yahoo to primera2.0GT
[quote]Originally posted by enzo@af
[b]Mash on it. Or, if you want to possibly break some stuff, and if your car will allow you to do it, rev it up while in neutral, then quickly shift into drive, or first. Not the smartest thing to do, but hey...I've seen it work*
hehe i did that wheni used to drag my old 86 sentra auto... it worked... untill i had to get a whole new tranny, aiya!
stop rev'in on me... i dont wanna race ...aiya!
Old 07-20-2001, 03:33 PM
kenchan's Avatar
kenchan kenchan is offline
yeh, the fastest way to get up to speed on an AT is to rev the engine up to about 2k-2.5k with your left foot on the brake. as the light turns green you need to time your right foot to the floor exactly as you let off the brake. you want slight wheel spin. leave the gear in D, let the AT shift up on its own. donno about OD, it doesn't seem to make any difference on 1-3 gears. (could be wrong as shift mapping does seem to change).
a lot of MT drivers suck at shifting (not that I'm saying that any of you here suck ) and found that AT sometimes accelerate faster than MT. gahahahaha!!! to you bog shifters. gahahaha!!!
..but again, the AT on our P11 is very sloppy compared to other AT's Ive driven. if you wanna drag, get a MT and learn how to shift. getting a AT looses about 20hp to the wheels just from that.
Old 07-21-2001, 02:43 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Hmm.... interesting topic... I've owned both an automatic G20 and a 5-spd G20 (current car)... The auto is slower off the line, but I could get better reaction times... G-tech testing showed that just mashing the gas is the best off the line (instantaneous G's measured by passenger), and the O/D didn't make a difference, and the shifter button (power/touring I think) didn't make a difference, if your foot was down, it'd go all the way to redline I also noticed on both cars, a good way to increase throttle response is to tighten up the throttle cable as tight as it'll go (with a little slack so it's not holding the throttle open of course). that makes a big difference in off the line feel of the auto and my shifting on the 5-spd too. With the cable tightened all the way, ripping gears is much easier (ACT clutch helps alot too ). BTW, I never really did an auto vs. 5-spd 0-60 or 1/4mi. comparison... BUT... I know my 5-spd is quicker off the line and it feels quite a bit faster in first. However, once into second it's even money, except for maybe the weight difference between the auto and 5-spd cars... 80lbs i think?
Wow, that was long
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 07-21-2001, 07:31 AM
kenchan's Avatar
yeh, auto's tend to loose within the first 1sec of the drag race. one would probably need to get a bigger faster motor if they wanna keep dragging with an AT.
also, unless you wanna get a cheep alternative to a universal muffler to get sound and looks, keep your stock muffler. my arospeed muffler looks and sounds good, but that 0-10mph acceleration is very sluggish now. no backpressure.
Old 07-21-2001, 08:37 AM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
Originally posted by JustinP10
[BI also noticed on both cars, a good way to increase throttle response is to tighten up the throttle cable as tight as it'll go (with a little slack so it's not holding the throttle open of course). that makes a big difference in off the line feel of the auto and my shifting on the 5-spd too. With the cable tightened all the way, ripping gears is much easier (ACT clutch helps alot too
Wow, that was long [/b]
So if I tightened the cable it would be bad for the tranny since it would rip the gears?? How do I go about tightening the throttle cable, because when I push on it, it does feel a little loose.
Old 07-21-2001, 03:33 PM
JustinP10's Avatar
On my car, you adjust it right between the throttle body and the Valve cover on the driver's side (LHD). there are two bolts that are on either side of a bracket. you can losen em up, then twist em both in the same direction (to tighten up the cable), then tighten them back up real good, don't want it slipping. I notice that with my 5-spd G20, when i shift real hard, at the drag strip, or anywhere for that matter, the shifts are harder when i have that cable tighened. Oh yeah, on my car, it's the cable closer to the TB, the lower one is the cruise control, i havn't messed with that one yet, don't think it's necessary either, not for performance at least.
My theory on the cable is that the throttle body opens faster because there is less slack in the cable, therefore when you push the pedal, the throttle body opens almost exactly the same time, instead of waiting until all the slack is tightened up, then opening... if that makes sense. I'm not sure how this could be bad on the tranny, other than the obvious, your ripping on the gears... that's stress on the tranny. Oh yeah, if you were to tighten the cable too much, your car would idle high, among other things, and I'm not sure how that would affect everything?
Justin McClanahan
95 G20
Old 07-25-2001, 11:25 AM
Jay Z 4885 Jay Z 4885 is offline
first mashing the trottle will only make the auto shift in first at 5000 rpm but if you slowly and linearly hold the gas and play around to find the sweet spot you will get the engine to rev near 7000 redline maybe about 200 short. Either it hurts the engine though to neutral drop it (put in neutral and rev the engine and then switch to drive) but that hurts the drivetrain alot. the other way is to brake gas it like everyone says. it will not hurt the engine as much because just like the manual the auto engages the clutch when you press the brake or else your engine will break so the brake gas is just like the manual. Also the overdrive is the fourth gear. Because the fourth gear is less than a 1 to 1 ratio with the final gear ratio. That means in fourth gear the engine will rev alot lower increasing the gas milage but slower acceleration. If you look the first, second, and third gears are all larger than 1. Pushing the overdrive just puts the gearing from fourth to third thus the reason why the car revs alot more
Old 07-25-2001, 12:29 PM
kenchan's Avatar
kinda forgot bout dragracing with this car and thought about better things...like how to turn off the damn service engine light...
Old 07-25-2001, 04:02 PM
primera man's Avatar
"P-Man"
This service lights gonna cause you to start drinking and going insane
View All My Models Here.
Old 07-25-2001, 05:05 PM
kenchan's Avatar
have already begun to sniff exhaust fumes... ahhhhhh!!!:silly2:
i FEEEEL GOOOD!:smoker2:
Old 07-25-2001, 09:14 PM
kenchan's Avatar
i tried both ways just now, power braking to 2k rpm and not before launching. the powerbrake does pickup more speed off the line no doubt. man, I should turbo charge my G too, then it wont be a sisssy car. hummm... gonna get flamed, I know it.
Old 07-25-2001, 09:22 PM
Koojo's Avatar
yes it does pick up more power. The best way is to make sure that you press on the gas pedal as you let go off the brake, so you will have that full burst of power. I dont use it much, just sometimes if I want to beat some car thats next to me at a redlight, or to show off to some people standing on the sidewalk...:smoka:
Old 07-25-2001, 10:44 PM
kenchan's Avatar
yeh, I use it often (more in 1.5k rpm area) when I wanna make quick lefthand turns at an intersection from a standstill. otherwise this AT just bogs up so much torque that it's a shame. :o
you ever notice dat the AT shift knob has some play on the shift button and on the shifter itself? wish there was a shift knob that would eliminate the play. i noticed it on the other AT P11's too. if we can rid this slop, it'd be more fun to drive it around while manually holding the gears.
wonder if the new celica's shiftknob fits on our cars...
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 07-25-2001, 10:48 PM
Koojo's Avatar
I havent really noticed that much play in my shift know for some reason
accelerator not responding buddahkat06 Accord/TSX/Accord Hybrid 2 02-26-2009 04:05 PM
Loses power under acceleration MikeS144 Metro 13 02-15-2009 07:56 PM
98 camry needs faster acceleration and body kits cheap!! brickwall88 Camry/Camry Hybrid/Vista 2 06-23-2005 03:48 PM
faster acceleration 2000_gs Integra 10 04-13-2004 02:23 PM
faster acceleration SnowboardGurly '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 05-22-2003 09:30 PM
