Old 12-15-2002, 05:50 PM
flyonthewall's Avatar
Car Mod guy
Originally posted by 935k3
What I have used a s long as I can remember is I take an old spray can with the lid on and wad up duct tape on top and shove it up under the roof of the car body. I like using the cans because they are round and easy to turn.
Ditto
Old 12-15-2002, 06:01 PM
auto auto is offline
Banned
I use old propellant canisters.
Old 12-16-2002, 08:34 AM
tonioseven's Avatar
Lightbulb
I use a bent hanger. :sun:
Old 05-10-2003, 11:07 PM
Gangrel52's Avatar
Gangrel52 Gangrel52 is offline
Send a message via AIM to Gangrel52
an old plastic cup, turned upside down..... kinda wedge the cup between the two 'doors' of the body. Works like a charm. Or... and old Spray Can. (After My cup was layered with Paint )
www.rearyracing.com
Old 05-10-2003, 11:34 PM
emufarmer's Avatar
emufarmer emufarmer is offline
Send a message via AIM to emufarmer
i just put some nails on a block of wood and it works pretty good
Old 08-07-2003, 05:01 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
But how do you guys secure the chassis? I'm building Kure Nismo GT-R, but I've just cut the chassis from the sprue tree and now I don't know to secure it!!
Old 08-07-2003, 05:17 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I use a old rattle can as well and bluetac the cars roof to the top.
The chassis I superglue (CA) a small plastic tube to a bit which will never show when finished on the inside and hold with a crocodile clip mount. I'll edit this post if I find a photo.
Steve a.k.a. Hiroboy
Old 11-11-2003, 01:53 PM
barryz28 barryz28 is offline
This tip is like the paint can and a wad of tape trick.
I like to use a plastic 2-litre pop bottle with tape on it.
Make sure you keep the cap and put it back on the bottle.
Why you may ask?
First, the bottle is tall, makes it easy to paint from almost any angle.
Second, It is easy to handle.
Third, I can add water in the bottle to weigh it down, and make a sturdy wobble free stand when painting.
Fourth, everybody has these lying around and they don’t need to be formed or bent to use.
If you can find and use bottles that are just as tall and have bigger caps on them, even better.
Old 11-11-2003, 03:09 PM
supramike420's Avatar
supramike420 supramike420 is offline
Send a message via AIM to supramike420
my jig
i used some 5mm brass wire and drilled 2 holes into a 2x4 about 4 inches long and put the wire in it, bent it to the right shape, and voila!!
Old 11-11-2003, 03:34 PM
ratdat's Avatar
ratdat ratdat is offline
It's the tall spray can for me too, only I use a full one as it's heavier. I like it because it's so easy to rotate it with one hand. A lot of bodies are narrow enough to just grip the sides of the can, iff not then some wadded gaffer tape or auto badge tape doest the trick. I find the Halfords cans are nice and tall and do the job nicely.
For chassis I do the same thing but just stick the chassis upside down on top of the can.
Works for me
Eddie
RATDAT.COM
Current projects...
Finished...
Old 11-11-2003, 03:45 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I use old coke bottles too, but I use the 20oz bottles, and turn them upside down. They are just a little wider than most models so there is a light pressure against the insides of the body and it holds tightly. I still double some tape to be sure it doesn't fall off. To keep it from falling over later, I'll stick in in a full toilet paper roll. I've been tossing around the idea of running a bolt up through my desk, and sliding a capless bottle over the bolt to hold it, I'm tired of my roommates complaining there's no TP. However, I'm sure they're tired of there being none........
Old 11-11-2003, 04:28 PM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Just as FYI, Tamiya is releasing a spray work paint stand very soon. Personally, I use Tamiya tall primer spray cans with tape on it cap for bodies & chassis
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Switching To WaterBorne Automotive Paint LearnAutoBody Auto Collision Network 0 04-13-2010 08:10 AM
Pain with Paint!! aonewordname Type 1 1 08-29-2009 09:34 PM
1970 Chevelle Paint job xraab Classic Cars 1 05-24-2009 08:53 PM
New Paint Color "HELP" panteli2011 Thunderbird 3 05-01-2009 01:40 PM
HOW TO: Neat Painting Jig ProSStreet Car Modeling 7 01-05-2004 12:12 AM
