| Maintenance problems, fixes. |
#16
Dead compressor
I had the same problem with my P10. As I recall, once the compressor really died, the charging and ventilation system didn't work correctly either, so I couldn't just ditch the A/C alltogether.
Replacing the stuff and recharging the A/C system was expensive (~US$900) but it was the only major repair that I ever needed to do to my P10. Don McLaurin |
#17
Ouch, that must have hurt. $900 dollars?! I guess I got a low estimate then. The mechanic that I went to said it would be only $420-$450. Maybe that is a testament of the quality of his work. You know cheap service means cheap work.
What do you mean they didn't work correctly, was it not charging? If that is so then I better repair it soon. Thanks for the advice. P.S. I did not notice until now that I made three posts in a row. You people must think I am a nutcase.:jump: |
#18
Slightly off topic here: Does anyone else's AC totally suck? Mine sucks a ton of energy, and it doesn't even do a good job of cooling things down... Is this normal? Should I have someone look it over?
oh, and the fan speed control is also shot (as in I have 2 speeds.... level 2 and level 4... I don't even get "off" as a choice) Is this tied into a bigger problem???
Like a boy - but BETTER! 2005 Subaru Forester 2.5X 1997 Honda Civic EX Coupe Inform yourself: AF User Guidelines |
#19
and the fan deal could be your blower resister, you can probably replace that yourself, i think its like $30 or so at the stealership, but i could be wrong
John H. 2001 Infiniti G20t - Aspen White Pearl For Sale: 18" Gold Axis Se7en's and Eibach Pro-kits also for a G20 P11. Check the Infiniti G20 Classifieds Here ***My G20 - Click Here*** |
#20
The G20 A/C is a sealed system, so it should never need a recharge (unless you do a motor swap or something like that). If it seems "out of refigerant", then you have a leak also.
G20t, the $900 was for a new compressor and evaporator unit, along with refrigerant recharge, $65/hr labor etc. That was at a dealer, so your costs may be less! When my A/C went out, the vent system also didn't work, and it spewed smoke into the cabin for a while...Not fun! Don McLaurin |
#21
