Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-09-2009, 04:00 AM   #16
wnt2gofst
Re: Just beginning need info
Could not find Iceman Intake. Lots of others on neons though. Which ones should i stay away from? what is the next best? What others would you recommend?
wnt2gofst is offline   Reply With Quote
Old 04-09-2009, 10:17 AM   #17
1997-Dodge-Neon
What if you use a 60mm Throttle Body?
1997-Dodge-Neon is offline   Reply With Quote
Old 04-09-2009, 12:33 PM   #18
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Next best is the 3.0L intake. No one makes an intake that puts the filter in the front of the car. They all rest over the exhaust manifold(HEAT).
What do you mean, what if you use a 60mm TB?
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 04-09-2009, 02:58 PM   #19
1997-Dodge-Neon
Thank You. Someone thinks like I do. Great minds think alike...
Old 04-09-2009, 10:03 PM   #20
wnt2gofst
3.0L intake off of what? What kinda work is involved and where do i get one? thanks again for the info.
Old 04-11-2009, 05:25 PM   #21
das2123
On any 80's Dodge 3.0L engine. You take the intake tube off of it and use it. Depending on what type of radiator fans you have, you may have to cut the tube and use some exhaust pipe to extend the tube. You will also have to cut/modify your battery tray to allow the pipe to pass through. Below is what you would need to look for in the junkyard.
2003 Dodge SRT-4
Old 04-16-2009, 10:38 AM   #22
wnt2gofst
Thanx for the pic and the info. i'll start hunting.
