Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-26-2009, 09:40 AM
wnt2gofst wnt2gofst is offline
Question Just beginning need info
i own a 95 neon sohc with 113k miles. Goal is to get more hp little at a time with reasonable amounts of money. i am bout to do a tune-up and i want to know what i can do tune-up related to achieve my goal. What r the best plugs, wires, and coil? And should i also get an ignition? What else? pleez i need info.
Old 03-26-2009, 06:47 PM
Bear Bear is offline
Re: Just beginning need info
First is this car auto or manual transmission? Then you could try a cold air induction system like an ICEMAN (maybe out there on Ebay or at Howell engineering) good for MAYBE 3-5 HP. Underdrive pulley will free up MAYBE 2-3 HP and a performance computer (MOPAR or AF/X, avoid JET) will give you 10-12 HP. The computers will also raise the rev limiter and speed limiter. these are starting points and remeber HP does not come cheap. Take a look at both MODERN Performance and Howell websites to get an idea of what is avialiable.
Old 03-27-2009, 06:48 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Stock copper champion plugs work best in the neon. Don't waste your money on split fire or platinum plugs. Magnecor and MSD wires are both nice replacements for the spark plug wires. But keep in mindm that plugs and wires don't give you added HP. Don't waste money on an ignition system unless you are ready to start plumping down some money and tuning the car.
As an alternative to the Iceman intake (best for the 95-99 neons) you can build your own 3.0L intake. If you have a manual transmission, then you have a 49mm throttle body(TB) on there. The automatic TB is 52mm wide. This allows your engine to breathe a little bit more.
2003 Dodge SRT-4
Old 03-27-2009, 06:20 PM
the car is automatic. and i do wanna start tuning it. i will start with those three things. is it worth trying to find a 3.0 out of a stratus? and is it pretty much bolt in? Or should i start lookin for a DOHC? Which would be the cheapest and easiest? Is it also just bolt in?
Old 03-27-2009, 06:31 PM
Not sure what you mean by looking for a DOHC, if you mean the intake, it is as restrictive as the SOHC, and the 3.0 liter intake will take some cutting. I built my own CAI by using 2" PVC (painted it)and plumbing fittings to take the tubing off of the TB, then across in front of the battery (I did pull the battery tray and slot the hold down bolt holes so I could slide the tray back toward the firewall a bit and allow me to the run the tubing down and in back of the grill (wanted to get the filter out of the engine compartment heat), I used a K&N Cone filter and put a K&N crankcase filter on the tube on the valve cover where the clean air tube came off to go to the intake assembly. Do not know how much HP I am really getting but it sounds Gnarly at WOT acceleration.
Old 03-27-2009, 07:17 PM
sorry i mean DOHC engine as to the SOHC engine. And 3.0 liter out of a stratus.
Old 03-27-2009, 08:42 PM
OK, I understand. I have a DOHC and yes it makes more horsepower stock, but, that 150 HP requires the use of premium fuel (something the sales folk do not tell you). The DOHC is a bit quicker, 0-60, but again unless it is a ACR or R/t the speed is limited to 118 MPH. I have the MOPAR performance PCM (again premium fuel) a Modern Performance UDP, the home made CAI, and a B&M short shifter. Since my car has the dual fan radiator, I had to move the battery box back a bit to accomodate the CAI (no big deal). Still she runs quick and at 70-75 MPH she will still give me 38-40 MPG.
Old 03-27-2009, 08:45 PM
i am just tryin to find out if an engine swap would be a good starting point. is it worth the time and money? should i just stick with what i got, and start from there? My engine is a 95 SOHC 2.0 with 113k miles. What kinda hp will you get from header and full exhaust? sorry lots of questions very interested. What r the easiest engine swaps? degree of difficulty compared to results i.e. hp gain?
Old 03-27-2009, 10:20 PM
First you need to figure out what your goal is. What do you want to do with it? Do you want to stay N/A or go Forced Induction.
The DOHC engine was over rated from the factory, so the 150 HP wasn't actually true. The dyno results I have seen on stock SOHC and DOHC engine was about a 5-8 HP difference. But the DOHC is quicker at the track where it counts.
2003 Dodge SRT-4
Old 03-28-2009, 09:06 AM
well N/A is the cheaper route for now. But eventually i would like to go turbo. I figure i would try to get the most out of what i got, before goin to FI. What is the average price of an engine with lower miles? DOHC or SOHC? Is the DOHC bolt in?
Old 03-29-2009, 05:19 PM
If you plan to go FI then just wait. No need to spend the extra money now. Spend the money on parts you will need for the FI route or just save up the money.
The DOHC bolts right in, but you will need some other stuff to go along with it such as: DOHC PCM, DOHC intake and exhaust manifold, DOHC wiring harness and so on.
2003 Dodge SRT-4
Old 03-31-2009, 09:22 AM
thanx for all the info!! i just need to get started. Going to look for DOHC. I got the hood already. Besides DOHC PCM, intake, exhaust manifold, and harnesses what else will be needed? Best places to find DOHC engine? Can you find brand new? how much if so? If i do get the Mopar performance PCM and stick with the SOHC do i still need to run premium gas? Again thanx for your time and the info.
Old 03-31-2009, 09:54 AM
Used Parts you can get are: (from a DOHC of course)
*Head with cams and valvetrain
*Intake manifold
*Exhaust manifold (or DOHC header)
*Intake assembly (why not go with an Iceman or 3.0L intake?)
*EGR valve tube
*Pistons (you can use SOHC pistons, but you will lose compression)
*Fuel rail and injectors
*Passenger side motor mount bracket
*Valve cover
*Cam gears
*PCM for your year of car, 95, 96, or 97-99 (why not get a Mopar PCM?)
*Power bulge hood or cut the bracing out of your current SOHC hood.
*You can opt for the dual radiator fans, but I don't think you need them even if you have A/C
New parts you should get will be:
*DOHC Headgasket kit
*Timing belt/timing belt covers (if you want them)
*Timing belt idler pulley
*Plastic thermostat housing
*Upper radiator hose
*Camshaft position sensor
*Spark plug wires
*Head bolts
*New gaskets where you will need them.
*I'd also suggest changing the water pump while you are at it, along with the new timing belt and tensioner pulley
You will also need to extend the 3 CTS (coolant temp sensor) wires so that they reach it's new location.
I doubt you can find a new one. You may be able to find a rebuilt one. Price....depends on where you are buying from.
If you have a Mopar PCM, you should run premium gas all the time.
2003 Dodge SRT-4
Old 04-03-2009, 02:43 AM
i was wondering about the ice man CAI, do they make it for a 95 SOHC neon?
Old 04-03-2009, 07:35 AM
It isn't being made anymore. You can find a used one on forums or on ebay often. It fits 95-99 neons.
2003 Dodge SRT-4
