| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#16
Re: 1st car: Paint questions
Bingo. There are intelligent people in the world after all.
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
#18
the advice here has really helped me, i've just started to get into acrylics, i previously only used enamels, and they were actually pretty easy to use, especially out of spray can. Now I have a question regarding painting a gloss white car. I have the Tamiya TS gloss white can, and im trying to paint my model. I primed the car with tamiya grey primer, but when i spreay the car, it seems to coat unevenly and looks almost watery, I believe i shook the can enough to mix it properly, I havent tried heating it the paint up with warm water though. It just seems very uneven, and the enamels i used went on very well and the finish almost always came out great. This is my first time using a spray can of acrylic, so i just want to make sure this is normal. Thanks for the help. |
#20
TS paints are technically a lacquer, not an acrylic - definitely not water based, at least, and require lacquer thinners instead of water or acrylic thinners for cleanup.
That being said - you may be trying to go too heavy on the first coats. You need to build up a good base of light mist coats before going for a wet coat. Also, for light or bright colors, your final primer coats should be white primer over the grey - this would be for whites, yellows, reds. Tamiya sprays are rather translucent, so spraying over a grey primer coat will darken the final color. I found the tutorials on www.italianhorses.net to be very helpful in getting a good finish when I was starting back into the hobby - I'd recommend checking them out for a good perspective. There is more than one way to skin a cat, but Alex's steps seem easy to me.
Jonathan Current projects: 1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745 Completed projects: 1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988 No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced. |
#21
Isopropyl alcohol is fantastic for removing Tamiya lacquers. You should be able to find 99% in most grocery or drug stores- if not, the 91% will do. It's best to soak the body in a sealable container. I like to use reusable plastic leftovers containers (also from the grocery store). It will strip the paint and primer, down to clean plastic.
TS colors often are somewhat translucent- so bright colors such as white, yellow, and red do need to be applied over a white base. Tamiya's white primer is perfect for this. Quote:
PHOTOBUCKET SUCKS |
#23
You are a wealth of information. I am going to research all your posts over the week-end, lots to be learned. Patrick |
#24
Great thread & always a few things you can pick up on - even when you've sparayed a few models & think you have it right. A couple of things:
Patrick, don't be afraid to experiment with different types of spray cans - just be certain on what carries the paint in the can (i.e. acrylic, enamel, lacquer, cellulose). Here in Australia, we can't buy cellulose paint & thinners in Auto stores (they're only available to trade) so I don't have to worry with that one, but I've recently started using a generic enamel spray range from this store, which is basically suitable for indoor/outdoor use. The range is pretty basic but for block colours, they seem perfectly adequate & at AUD4 for a can the size of a water bottle against about AUD13 for a Tamiya spray, represents GREAT value. I've just finished spraying up Tommi's 2000 MC Evo6 with this brands Scarlet Red - awesome colour; really bright, & referring to another post here about Tamiya's rattle can gloss white, the gloss white sprays much better with more coverage (I've always had problems with Tamiya's white). MPWR: I'm confused why you recommend stearing clear of Testors' spray cans. I used their bright yellow to spray up a Revell 'vette Z06 for the old man. Great colour. Awesome depth to it. Anyhow, hope this has helped you as well Patrick |
#25
I will definitely experiment with some non hobby brands that I read are being used here in the states for car modeling. I know there is some money to be saved, I just need to get a hold of some junk plastic cars to experiment first, I don't want to melt any model I want to keep. For my first car I will definitely use a hobby brand recommended here like Tamiya or testors. I have been modeling military subjects for a few years and my primer of choice is Krylon which isn't made for the hobby but is cheap and works well for my needs , I have read some modeler stay away from it like the plague and I wonder why ? Thanks and best regards Patrick |
#26
Testors does have a new line of lacquer- but I can't say much about it as I haven't tried it. But Tamiya TS really is a terrific product. It is worth a dollar or two more a can, easily. Paint is not a place to cheap out, and it is not something to rush. Stripping and repainting always costs more time and money than using good paint the right way, and getting it right the first time.
PHOTOBUCKET SUCKS |
#28
I found that spraying a soda can or two helped me develop my skills without jeopardizing my precious car bodies until I was satisfied with how things looked and reacted. I still shoot a test panel each time I spray a new color/primer combination. I think colors, like people, have personalities and some take time to get to know or just won't get along no matter how gorgeous the container is.
#29
I use plastic spoons to test my paint as it has all the types of surfaces, edges, corners and recesses that a model car can have.
If you can paint a plastic spoon evenly AND polish it up, you will have no problems with a car body.
#30
Good tip drunken monkey.
