Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 02-26-2003, 07:43 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Originally posted by MetalGod
You will need air with that fuel. No this will not work on carb cars.
... Yeah, i've got the air part covered... Nice intake, Heads and a big Cam....
What wont work on carb. cars? Porting the intake/heads?
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 02-26-2003, 08:04 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
You really should try porting your intake base at the heads side about 2 inches in. this will siamese the whole manifold, thus double the airflow. Use a large cam around 226 or bigger on duration and around .470 + lift with a 106 deg lobe sep. Now you must use a tight lobe sep for everything to work right. not the wide pattern normally found in fi and stuff. So far i have had really good luck with the siamesing. Everyone that i ever mentioned this to said the car would NOT start. When i got the car together today, the car started on the first piston that fired. If , if i lose some bottom end, i will stall it hence i was going to put a 3000 rpm in it anyway.lol. What good is 25 more ft lbs of torque if a forth gen camaro ss is going to wipe ur @$$ at the other end. I will test the trap speed again and see if i had gained any.
WOAH...A degree lsa!??? That's pretty extreme, don't you think? I am running a 110 right now and my car lopes A LOT. Idle is pretty damn rough on my 110. I used to run a 114 on my first hydro cam, and then a 112 on my second. Moved down to the 110 only when I put in the solid. I would also think that a 106 would have problems starting and staying alive...Got any sound clips? I bet it sounds like a top fuel
There's no replacement for displacement...No, not even a turbo.
Old 03-02-2003, 04:29 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The Ford 302 heads are not great but better than Chevy 305 heads. Thing that seperates the 2 blocks the most is Ford's use of a roller cam with a much better profile than any Gm cam through the 80's and reduced friction. While GM stayed with a flat tappet cam until the LT-1.
I think you should just go 350 shopping unless you got a real hard-on for the 305 though
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-02-2003, 12:37 PM
MetalGod MetalGod is offline
aH, Gm's had roller since 1987. My 87 Iroc has a roller cam.
Old 03-02-2003, 12:43 PM
I ran a crane 100082 cam in my 305 formula and all the mods were a 1989 corvette chip. The specs were 226 @ .050,.470 lift and 106 lobe sep andground 5 degees advanced. Yes it idled like a stock car @ 500. very rough. around 6 inches of vacuum. it did run a bit better. i still have the cam. i am going to put it in my iroc
