Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-21-2003, 06:56 PM
neonrcr95 neonrcr95 is offline
Send a message via AIM to neonrcr95
Just to point this out even if a neon and skyline did race look at the diferences. 2.0 i4 compared to a 3.0 i6. Neon front wheel drive comapared to skyline all wheel drive. Neon stock no turbo compared to skyline stock twin turbo. So even if the both of these cars raced the skyline still has the advantage over the neon even if both are modified. So really it wouldn't be a fair race.
Old 02-21-2003, 08:31 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Originally posted by DOHcNEON
i am told that it is a fuel injected 360.
Man, just drop the new Hemi in that puppy!!!
Old 04-01-2003, 12:56 AM
morimotor34 morimotor34 is offline
Lightbulb Neon vs. Skyline
Ok. Allow me to shed some light on this controversy. First off, neonrcr95, stock skylines run at 2.6 not 3.0. Next, stock R-34s run the 1/4 in the high 13s to low 14s so if your neon is running 11s or 10s then of course you'll win. Also, as posted earlier, a stock skyline is slower than an NSX. Along with the whole 1/4 argument, in order for a skyline to run in the 11s or 10s, it needs to be boosted to 600-700 HP, which is way under an RB26's threshold. That's the deciding factor, however. The RB26DETT is perhaps the most tunable engine ever created. Numerous examples exist in Japan that put out well over 800 HP. And yes, some put out as much as 1300 HP. It is very easy to extract absurd amounts of power from the RB26. So, if we're talking about his neon versus a stock skyline, then he'll win walking away. He would probably winn over a slightly to moderately tuned skyline as well. However, against a more highly tuned skyline, goodnight! Not a chance!! Maybe this will clear everything up and stop everyone from bitchin' back and forth.
Old 04-01-2003, 01:01 PM
DOHcNEON DOHcNEON is offline
i have only put about 7 grand into my car. Including the car. How much do Skylines go for these days?
1998 Dodge Neon
2.4 dodge stratus motor.
Hahn Racecraft stage 4 turbo with front mount intercooler.
JE Pistons 8.8:1 compression with eagle rods
bored .20 over
60mm TB
balanced and blueprinted engine
custom blackdog race ported head
Custom ground crane cam
Crane racing valve spring and retainers
unorthodox Underdrive pulley
AEM cam gears
MSd ignition
magnecor wires
iridium plugs
custom borla exhaust
stage 2 racing axles
Clutchmasters stage 4 clutch
fidanza lightened flywheel
17" rims
Old 04-02-2003, 06:03 AM
Skylines are'nt cheap at all. A company called MotoRex imports skylines and makes them street legal. New R34 GTR V-SPECII run upwards of $85,000. Pretty stinkin' expensive. Older models (R32, R33) cost $30,000 and up (way up) through MotoRex also. Now, you can do a gray market import in which you have a skyline imported for "off-road use only". You basically buy it in Japan and ship it here. Shipping will run you around $4,000 but Skylines are actually quite cheap in Japan. Low mileage, used, late model GTRs will run around $30,000. It's possible to find used R32s and R33s in Japan for $20,000. Regardless, it's still gonna cost you $30,000+ to get one over here. For a street legal version quite a bit more.
Old 07-01-2003, 01:28 PM
lakai_sk8 lakai_sk8 is offline
v8 conversion
wats up. I am planning on doing a v8 conversion on my neon. either a 318 or 360. I was hoping you could help me out with giving me info on everything I need to do to make this happen and the companies that provide the parts needed for the conversion, like motor mounts, rear ends, everything like that. thanks.
Josh
Old 07-01-2003, 02:38 PM
AstroLuin AstroLuin is offline
Send a message via AIM to AstroLuin Send a message via Yahoo to AstroLuin
Question
ok, im sticking with the subject
Where did you get that picture?
Id like to know how they moved the battery to the passenger side, and to top it all off it looks like the ac is still installed. Now why would you move the battery on the other side of the hood and keep the ac in a v8 swap in a itty bitty engine bay? Oh and where is that hose on top of the thermostat going to, the fog light hole???
I would like to know more about that "v8 neon".
Luin Haden
Owner of two Chevrolet Astro Cargo Mini Van's (88 & 92)
[email protected]
www.astrosafari.com
Old 07-01-2003, 11:53 PM
ThaLegend ThaLegend is offline
Originally posted by Polygon
What is it with people and the ignorance that the Skyline is the god of cars???
Skyline God of all cars...??? It is just a car like the rest... My car can beat a Skyline GTR... But my point is any car can beat a Skyline GTR, its not "GOD" its a nice car dont get me wrong. That neon that guy with the Stratus engine he can beat a Skyline A skyline with 1300 hp... that shit is in "JAPAN" only no here in the states has that kind of power on a SKYLINE...
Q= Can I beat a Stock Skyline? A= Yes
Q= Can "Stratus engine swap guy" beat a Stock Skyline? A=Yes
Old 07-02-2003, 04:02 PM
Polygon's Avatar
The Red Baron
You know, I agree with you fully.
Old 07-03-2003, 11:20 PM
TurboB15sentra TurboB15sentra is offline
Send a message via AIM to TurboB15sentra
I'll vouch for the Neon's capabilities with a turbocharger on it. Have any of you ever seen Forward Motion's turbo neon? It's in the 8's or 9's I believe. This is on the stock block too.. with internals of course.. but stock block! I've seen several turbo street neon's in the 11's and 12's.
Travis
www.forcedinductionracing.com
Old 07-03-2003, 11:23 PM
That's no necessarily true... There are several 1000+whp R33 and R34 GTR's in the states. I promise you, if you run across a 1000whp AWD GTR V-Spec II, you won't touch it with anything short of a car running 8's. I've seen/ridden in a car that JWT did some work on that was making 600whp.. and it ran mid 10's all day long. This was on a bone stock RB26DETT with turbo, ECU, injector, intercooler, and exhaust upgrades.
Travis
Old 07-04-2003, 04:04 PM
QuickMaxima QuickMaxima is offline
Originally posted by B16EJ1
That's a bold statement my friend. I hope you're pushing well over 500hp and if so I'd like to see the dyno results to prove it. That's the one claim that should'nt be made with a neon even with a boosted stratus motor I mean we're talking a TT inline six. I'll post a dyno video with an average Skyline that is off the dyno charts. I've seen a Skyline that has 1300 hp so are you sure you are talking about a Nissan Skyline GTR???
Skylines are just average cars when they are stock. Stock Mustang GT's (00-03 model years) can run high 13's to low 14's all day long, just like the Skyline. Only you can get a new GT for $22.5K out the door as opposed to the $40K+ price of an imported R33-34 GTR. The Subaru STi and Lancer EVO are faster than a stock Skyline R33, and the Neon SRT-4 is right behind those cars. Skyline is a good car, but it's only great when it's extensively modded. By the time you get a Skyline to the low 12's in the 1/4, you could be doing that time with a stock '03 Mustang Cobra for less than half the price. It's all relative...
Old 07-04-2003, 04:12 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
drop the fuckin skyline bs, i want to know more about that neon
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 07-11-2003, 01:07 AM
Thank you! Finally someone else with the same question as mine. geez people, there is a nissian forum here.
Luin Haden
[email protected]
www.astrosafari.com
Old 07-11-2003, 01:11 AM
Post
Oh and I noticed something else....
They used the factory radiator for a v8?!?!? uh?
Luin Haden
[email protected]
www.astrosafari.com
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Engine Swaps For 2003 Neon?? Tiffany2269 2nd Gen 00-05 2 03-13-2007 01:07 PM
A REAL engine swap diegoaccord Neon | Plymouth Neon 25 01-07-2005 06:41 PM
engine swap 2000 neon zacpobroma 2nd Gen 00-05 0 05-24-2004 03:27 PM
