Old 01-16-2003, 04:29 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Usually, you have to use two different kinds of paint for washing.
The body color shouldn't be affected by the solution of the washing paint.
Enamel on lacquer based acrylic works.
Water based acrylic on enamel works, too.
And water based acrylic on lacquer based acrylic also works.
You can't really do washing if you only have one kind, even though completely dried paint isn't supposed to be dissolved so easily.
I'd recommend to buy a fine pen at some of those art supply stores.
Also, you can drop excessively thinned black at corners, and let the capillary action flow the black paint along the grooves. You can obtain even finer lines by doing this.
Hiroaki Fukuda
Old 01-16-2003, 04:33 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
lol thisi isnt for the car body, im trying to black wash a tranny and engine block
Rui
(modeling) = Click Here
Old 01-16-2003, 04:41 PM
flyonthewall's Avatar
Car Mod guy
Originally posted by fullbloodchop01
ive been trying to do some black washing ut it doesnt seems to be working weel, im using testors bottle paint because thats all i have right now, im using some black testors acrylc paint thinned w/ water and it just seem to beed up on the part i want to black wash???? WTF can some one help me please
The problem is surface tension, water is not the proper thinner to use with acrylics although it does certainly thin the paint. In the future get hold of the appropriate thinner, in the mean time use some dishwashing detergent in your watered down paint. You only need a tiny spec, so just dab the end of a cocktail stick into the detergent then dab into the thinned paint, that's it!
Old 01-16-2003, 04:51 PM
thanks FOTW but what is the best thinner? do you think that alcohol will work better than water? also i want to know what i should thin my paint in so i can use the right amount of detergent, and by the way what does the detergent do any ways?
Rui
Old 01-16-2003, 05:03 PM
Mr Mario's Avatar
Mr Mario Mr Mario is offline
That's good but what do you do.... when your main body is acrylic?
I like using Tamiya acrylics with the air brush I have some trouble doing panel lines when the paint is thinned down using Isopropyl alcohol.
The paint dries way too fast and if I screw up it pisses me off!
Help if you can't oh well
Old 01-16-2003, 05:05 PM
Vric's Avatar
Vric Vric is offline
UI will order some Gundam marker ! but for now, I use some Acrylic Black with Water... easy to wash and make a nice job......
Old 01-16-2003, 05:10 PM
Car Mod guy
Best thinner for acrylic paint???...erm...err... Acrylic paint thinner!!!:finger:
As i say, you only need the tinniest spec of detergent so use the cocktail stick. The detergent breaks the the surface tension - haven't u ever seen that thing with the matchstick? Nevermind! Use things like can lids, bottle top or artist palettes for mixing your paint.
Old 01-16-2003, 05:12 PM
im a little slow today:frog:
and what about the alcohol??? i dont have any ACYLIC PAINT THINNER on hand right now
Rui
Old 01-16-2003, 05:20 PM
hirofkd's Avatar
I avoid using water based paint for the body, but if I don't have any choice, (like when I was in the U.S., and couldn't get Mr. Color so easily,) I use micron pigma .005, Rotling drawing pen, or even 0.3mm mechanical pencil.
Hiroaki Fukuda
Old 01-16-2003, 05:35 PM
Car Mod guy
al·co·hol
(lk-hôl, -hl)
n.
A colorless volatile flammable liquid, C2H5OH, synthesized or obtained by fermentation of sugars and starches and widely used, either pure or denatured, as a solvent and in drugs, cleaning solutions, explosives, and intoxicating beverages. Also called ethanol, ethyl alcohol, grain alcohol.
Intoxicating liquor containing alcohol.
Any of a series of hydroxyl compounds, the simplest of which are derived from saturated hydrocarbons, have the general formula CnH2n+1OH, and include ethanol and methanol.
I dont know about using it as a thinner, drink some and see what happens
Just carry on and use the water for what your doing, i was just pointing out that there is a proper thinner. I do use water to thin acrylics when doing panel lines and sometime with washes as its not going to attack the underlying paint so much. Use the detergent and also experiment with larger ratios of water to paint.
Old 01-16-2003, 05:58 PM
daggerlee's Avatar
Isopropyl alcohol = rubbing alcohol, go to your local drugstore and ask them for it, if they don't have it I'll buy you a new kit
Mr. Mario, then maybe you should try clearcoating with a lacquer like Tamiya TS-13. Just be careful to lightly mist your first 4-5 coats on to build a barrier for the wet coats.
Dan
Old 01-16-2003, 09:53 PM
Mr Mario's Avatar
Hey I never thought of that!!!
Have you ever tried it? If so how long do you let the body cure for (using tamiya acrylics) before you apply the lacquer clear coat? I never tried it!
Man you a smart guy!!:sun:
Old 01-17-2003, 12:25 PM
ok thank guys i think i have a pretty goood solution goin but, the main question now is how do i apply the stuff??? do i just brush it onto the part and wait for it to dry????
Rui
Old 01-17-2003, 12:36 PM
Car Mod guy
http://www.briansmodelcars.com/tutorials/pdf/7.pdf
Old 01-17-2003, 12:59 PM
thats a good tutorial but what im talkin about is on small parts, like engines ans other little pieces like that
Rui
AMG Black Series Christer Olausson Other Cars 2 03-08-2010 06:02 AM
waterless car wash veron Cars in General 0 03-04-2010 11:31 PM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
black wash 91p10nizmo Car Modeling 15 05-25-2004 12:58 AM
black-washing Vric Car Modeling 4 06-07-2002 02:19 PM
