Old 11-24-2002, 07:15 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
ok yeah the ls has a better comp ratio, but it has the worst rod ratio ever, you have to worry about breaking rods and the cylinder walls.
with the b16 you do have to worry about comp ratio, but you dont have to worry as much about breaking a rod or putting a piston through the cylinder walls.
if your running 11psi then you should build your block anyways, so if you buy aftermarket pistons, just order lower comp pistons and its all good. the #1 failure with ls's from what i hear is them breaking rods, i never really heard anything bad with the b16
Old 11-24-2002, 04:01 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
how bout the b18a in my 90 Integra?
Anybody have any turbo experiences with this motor?
Would this be a good motor to turbo?
Any ideas on a price for a kit?
TIA
Old 06-17-2015, 03:10 PM
WinksEj8 WinksEj8 is offline
Re: Found a B18, non-vtec, worth it or not?
just bought a b18b for 850$ with 30K on it, its a good strong motor. Good for boost cause low compression
B16 bottom end with B18 non vtec head????? civic&240 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 12-22-2009 05:17 PM
b16 or b18 non vtec fredthedragon '88 - '91 Civic | CRX | Wagon | Shuttlee 21 12-03-2003 03:44 PM
sports buttom not working on auto prelude 2.2 non vtec crxvti Prelude 0 07-11-2003 09:01 PM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '71-'87 Civic | CRX 1 06-24-2002 11:43 PM
Vtec Head on Non-Vtec? H22-Civic Si '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 05-19-2002 07:59 PM
