Go Back   Automotive Forums Car Chat > Automotive Art > Car Modeling > WIP - Muscle Car / Hot Rod
WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum.
Old 03-22-2007, 07:40 AM
modeltech modeltech is offline
Send a message via Yahoo to modeltech
Re: ´70 Cuda
hey bro, go with the modern injected engine!! the g-force stuff is sweet!!!
Old 03-22-2007, 11:35 AM
mopar man's Avatar
mopar man mopar man is offline
Re: ´70 Cuda
this is looking spectacular man hope to see more real soon!
I stepped on a Cornflake, and now I am a cereal killer.
Old 03-23-2007, 09:20 AM
Bossolani Bossolani is offline
Re: ´70 Cuda
Thanks guys!!!!
I still doing something like a Sick Fish on rear. So I add 2 stirene 1mm tube piece and after cement cured I sanded the wing.
I scribed trunk lines
And i joint all with tamiya epoxi putty.
I don´t sand nothing yet....
Sorry for poor english again....
Cesar Bossolani
Old 03-24-2007, 02:18 PM
Re: ´70 Cuda
spoiler looks good!!
Old 03-24-2007, 03:33 PM
slimsi99 slimsi99 is offline
Re: ´70 Cuda
Man, this is looking sweet. The sick fish is a nice one to model after.
The english is fine, don't worry about it.
Name is Brett use it if you want!
I'm so far behind I think I'm in first!
Old 03-24-2007, 08:49 PM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
Re: ´70 Cuda
Awesome!! I have a little question:
Wich Tamiya Knife is that? Is it a Crazy Modeller Saw adapted on it?
"Oh noez,it has more stickers than me! And a wing too!
Old 03-25-2007, 03:10 PM
Re: ´70 Cuda
Thanks guys!!!
rod k2 all tamiya...
Cesar Bossolani
Old 03-25-2007, 09:17 PM
Alfa 147's Avatar
Alfa 147 Alfa 147 is offline
Re: ´70 Cuda
Awesome progress so far! I would go with the sick fish engine, looks a lot cleaner
Alfa147Models.tk (in spanish)
Old 04-02-2007, 07:16 AM
Re: ´70 Cuda
Thanks guys....
I did scratch build rear suspension... Now I have a Four-link sistem!!!!
1st I did a pre assembly
I did cuts on floor.
And i did suports w/ stirene sheet.
Assembly
Inside floor adaptions
Bars made from 1,0mm wire and 2,0mm stirene tube
After that I did other pre assembly. I did both holes for shockers.
inside floors I add 1,5mm wire.
And finished with stirene
Another pre assembly...
Clean out old suspension sistem.
And finished...
Thanks for looking... sorry for my english!!!
Cesar Bossolani
Old 04-02-2007, 08:47 AM
tonioseven's Avatar
Re: ´70 Cuda
Excellent craftsmanship!
Old 04-02-2007, 10:55 AM
rsxse240 rsxse240 is offline
Re: ´70 Cuda
don't forget to install your panhard bar. without it, your rear end will move side to side (in real life). you seem to be one for an extreme attention to detail, so I just thought I'd add that little bit in case you forgot.
excellent build though. if it turns out half as nice as your Maverick, it will be a real show stopper for sure!
Old 04-02-2007, 02:22 PM
Re: ´70 Cuda
Thanks brothers!!!
rsxse240 thanks for attention and cool comments about Stallion Mav (they finished). But can you post some pics for refference. You are 1st people talk about that. So I´m still confuse... Please post it....
Thanks
Cesar Bossolani
Old 04-02-2007, 05:23 PM
Re: ´70 Cuda
there are a few ways to go about it, really. 2 ways are a triangulated 4 link (the other way in the image), and the afore mentioned panhard bar (mostly used on hot rods and trucks). you would use a spherical bearing, or large rubber bushing in real life at the ends of the panhard bar or triangulated 4 link bars. Nascar uses panhard bars. usually a panhard bar would be used on a suspension with longer radius arms (4 link bars) and the type you are building would usually have some sort of triangulation, but some setups with shorter radius arms do use panhard bars. you can actually connect the panhard bar to the diff housing, or anywhere on the frame, so long as the suspension travel doesn't cause the panhard bar to swing the rear end to one side under heavy load, or when the suspension becomes decompressed.
google image "four link rear suspension" and I'm sure you will find a host of reference pics to find the set up that is right for your application.
Old 04-04-2007, 07:59 AM
Re: ´70 Cuda
Thanks brother!!!! I understood!!!!!
Thanks for help!!!!
Cesar Bossolani
Old 04-04-2007, 09:08 AM
Risko's Avatar
Risko Risko is offline
Re: ´70 Cuda
Cool stuff!
