Old 08-06-2003, 08:49 AM
Randyman49 Randyman49 is offline
electrical and vacuum problem with 96 s-10 blazer
My 96 S-10 Blazer has a problem even my dealer can not find. The volt meter reads low and fluctuates. When I accelerate the air conditioning virtually turns off, or gets very low. The battery is new and good, the alternator is new and good. The fuel pump has just been replaced. The dealer said everything is within specs. But when they replaced the fuel pump the volt problem dissapeared for 4 days, then it returned. The A/C problem was non existent until the volt meter started flucuation. When it does ( kick in) the a normal charge mode. 14 volts. Everything works fine. Please help. What could be causing this voltage drop? Could ther be a vacuum issue when accelerating? Has anyone had these problems. Thank you in advance. Randy
Old 12-23-2003, 04:54 AM
vinnie97 vinnie97 is offline
All you need to do to fix the front wiper problem is pull the circuit board out of wiper motor and re-solder all the connections that go to the plug. If you look at these connections with a magnifying glass you will see that they are all cracked. I fixed so many of these for friends and family.
Old 04-15-2004, 02:19 PM
jpollina64 jpollina64 is offline
Re: 1997 S-10 Blazer Dont know whats wrong!
My rear wiper has stopped completely, fronts work fine. What is the best action to take? I will take off the trim, but does anyone know if you need to take off the inner panel to get to the wiper motor. If so is this complicated?
Old 04-17-2004, 07:22 AM
mayville1 mayville1 is offline
Send a message via AIM to mayville1
Is the wiper motor strong enough to move them or do you need a new one?
Old 04-17-2004, 03:25 PM
mekanic1 mekanic1 is offline
Question My 91 does the same
Hey my 91 s10 blazer does the same thing with the windsheild wipers. is this a common problem for all models or just specific years? and if so is this the same repair procedure??
differnt mechanics dont know whats wrong? JeepTrick5 Grand Cherokee | Grand Cherokee SRT8 2 12-01-2006 01:54 PM
Dont know whats wrong sanzoneb 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 13 10-13-2005 01:23 PM
dont know whats wrong aharte Let's get Technical! 11 06-01-2005 02:51 PM
Help! I dont know whats wrong with my car tugg 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 06-16-2004 04:04 PM
car will not start dont know whats wrong h22hatch91 '88 - '91 Civic | CRX | Wagon | Shuttlee 20 05-18-2004 09:47 PM
