Old 05-14-2004, 09:41 AM
h22hatch91 h22hatch91 is offline
car will not start dont know whats wrong
went to school in my civic and came back out to go back home and car would not start. when i turn the key it doesnt make any noise at all the lights still come one and i had someone try to jump it just in case but still did not start. cant figure it out but any help would be great
Old 05-14-2004, 10:02 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: car will not start dont know whats wrong
bad starter? loose starter wire/ground?
SOLD!
Old 05-14-2004, 12:15 PM
travagliante's Avatar
travagliante travagliante is offline
hmmm. when you turn the key to ACC. do all the dash lights light up.... Because if the they do just try pop starting the car with a hill.
Old 05-14-2004, 12:17 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
clutch switch?
see if you are getting power to your starter w/ a multimeter.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 05-14-2004, 12:19 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
are you getiing spark, and/or fuel, could be your dist. or your main relay
KoRnSaQ
Old 05-14-2004, 01:00 PM
Bxcivic2000 Bxcivic2000 is offline
I have gone thru that recently also, my car not starting, there can be a number of things to consider, some of the guys already mentioned some, how about your main relay, your fuel pump or filter.
In my case it was the main relay, I was ready to replace the fuel pump, so better to check everything, and save money too.
Good Luck
Bxcivic2000
Old 05-14-2004, 01:49 PM
marked001's Avatar
Moderadur
seems like the obvious places to start are the starter, starter connectin, or clutch switch since the starter isnt even running..
SOLD!
Old 05-15-2004, 09:37 AM
i got my starter tested and it still works and the lights still come on on Acc i also checked the main relay and its still good. where is the clutch switch?
Old 05-15-2004, 09:42 AM
i wanna make sure , is the main relay the little black box under the driver side dash on the left? or did i check the wring thing
Old 05-15-2004, 09:47 AM
how would i test the started with the multimeter do i just connect it to the wires that go to the starter?
Old 05-15-2004, 04:47 PM
i got the car to start by popping the clutch but what is causing it not to start without having to pop the clutch. when i turn the key it makes no noise at all no clicking , nothing at all. so i have no clue what it is
Old 05-15-2004, 06:10 PM
Doc Jones's Avatar
Doc Jones Doc Jones is offline
Send a message via AIM to Doc Jones
Try tapping the starter a few times with a hammer, if it starts up, then you need to start lookin in to a new starter. That might get you by for about a month, so if this is the case start sweepin the junkyards. Starters are normally fairly easy to install. I've had to do em for toyota's, hondas, and even a 1970 dodge colt, and as long as you ahve some light or are good feelin around in the dark it's a snap. 2 bolts and a couple wires.
Old 05-16-2004, 12:12 AM
i got the starter tested and it works and the battery is good too soo...
Old 05-16-2004, 12:21 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
Same thing happend to me, i thought it was the battery i charged it up and then still nothing. My dad told me to go out and tap the starter with a hammer, i was like what the hell, i went out there tapped it a few times and it fired right up. Try it
88 civic dx
Old 05-16-2004, 12:39 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: car will not start dont know whats wrong
sounds like ur soldenoid on the starter is weak, usually on a bench test it will come up fine, but on the car under load it may strain and not turn over at all, also, u could have cooked a fusable link in ur starter wiring, check the wires from the starter and make sure there are no brakes in the lines
