Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-11-2005, 08:59 PM
sanzoneb sanzoneb is offline
Dont know whats wrong
The other day i drove my 91 300zx in a rain storm and it just died on me.
I got it towed to a shop and the starter died but that didnt fix it.
He think the connecting rod broke but i talked to another person that used to work in the nissan service department that doesnt think that the connecting rod would break that easy. I definatly didnt hear anything snap either. The car just died on me. I tried push starting it and it tried to turn over but wouldn't. Any ideas, please help
Thanx, Ben
Old 10-11-2005, 09:52 PM
probehtr300 probehtr300 is offline
Re: Dont know whats wrong
yeah, try replacing the starter relay. its a $10 little blue box hiden behind the inner drivers side fender cover. trust me
Past Z Car Crew
-josh
Old 10-11-2005, 11:13 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
sounds like your engine became water-locked. but pray to god that didnt happen because that siezes up your engine.
ZedEx Crew Member #2
Old 10-12-2005, 09:25 AM
Hodo Hodo is offline
It doesnt sound like your engine is hydro-locked. You would have had to hit a DEEP puddle for that to have happend. But it does sound like the wet weather did make other things fail, check your starter relay. Then check your ignition system make sure that your....... brain fart, cant remember what there called, the power booster, things, that always fail on earlier Zs. Someone can tell you what they are called. But they will cause this problem too. Sorry cant be more help.
Finaly got pics of my car....... after I washed it of course.
Old 10-12-2005, 12:37 PM
well upon reading your post again i dont think its the starter relay at all. If it tries to turn over the starter is getting power. if u turn the key and get absolutely nothing then id say the relay is out, but if it does try to turn over keep looking cuz it wont be the relay.
Past Z Car Crew
-josh
Old 10-12-2005, 01:54 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Check your relays and fuses... It doesn't sound like it got Hyrdo-Locked. It is probably something simple, so don't stress it too badly
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 10-12-2005, 03:44 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
i think Hodo was referring to the PTU (Power Transistor Unit).
it was in recall in the earlier Z's. make sure you have a sticker under your hood signifying that you did indeed have this replaced. if not, call the local nissan dealership with your VIN number in hand and they will see if your car qualifies for the recall.
this is a very common problems in the earlier Z's. it's failure acts just like you described. sudden power loss and then it dies, then it will not start again. have the shop that its at test it with a multimeter and see if the OHMs are within spec according to the Z32 bible.
good luck man.
ZedEx Crew Member #4
Old 10-12-2005, 05:37 PM
thanx a lot everyone,
the mechanic thinks i may have dropped a value into the cylinder, he isn't positive i will metion these things to him though.
thanx, ben
Old 10-12-2005, 06:09 PM
Z Cars Fanatic
thanx, ben
did you even run over a puddle? for the engine to become hydrolocked you would have to literally suck up nothing but water. just soaking up a little moisture will only screw with sensors and vaporize in the intake stream or engine.
Old 10-12-2005, 07:20 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
yeah... and unless you have a DOOLZ kit, you'd need to prettymuch drive the car into a lake for that to happen...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 10-12-2005, 07:23 PM
The mechanic said there was water in the engine, i also herd the timming gear might be screwd idk i'm hearing a lot of things.
Old 10-12-2005, 07:24 PM
DeleriousZ's Avatar
yeah, sometimes they'll spit a lot of information at you to try and confuse you so you spend money you don't have to... mechanics are a hungry breed... well most of them... hodo is a good guy
Old 10-12-2005, 07:39 PM
Z Cars Fanatic
timing gear? find a new mechanic. do not spend anymore money with that guy, he sounds real iffy about his details. a mechanic not fooling around will tell you exactly what is the problem and how much he charges to fix it. he wont beat around the bush.
Old 10-13-2005, 01:23 PM
Thanx K3, I could for the life of me not remember the name of it.
Like I said though check your PTU. Because thats about exactly what it sounds like. Its ALOT cheaper than replacing a dropped valve or gettin butt raped without the benifit of a reach around by some blood thirsty shade tree mechanic.
And as the others said, I am a nice technician, I give my victims.... I mean customers a kiss on the neck to let them know when I am comming. LOL.
