Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-06-2006, 02:54 PM
ricebike ricebike is offline
Re: Engine Overheats
sal,
u shoulda made a separate thread, but since this is kinda relavent...
did you confirm that your fans work? you can bypass the relays & jump the terminals to the battery to see if they work... or you turn on your air conditioner or defrost-windshield mode to see if the fans turn on...
if they go on, then it may have to do w/ the coolant temp sensors... you can goto autozone for a free OBD II scan as well to see if any trouble codes were stored.
or you can try to find the ECT sensor & see if the plug-wire connection is corroded...just clean it off w/ a wire brush & some brakecleaner
http://www.troublecodes.net/Nissan/9...00.shtml#95max
P0125 is the Engine coolant Temp Circuit...
Old 11-07-2006, 12:47 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
vovw, how u found an anciend thread...
If needle doesnt rise, that is a problem itself.
What happens if/when your engine overheats?
Check/tighten belts first. Then fill up & bleed air bubbles out as FSM suggests.
Most common overheating causes in this order:
- loose belt,
- by low liquid level (system leaking),
- airbubbles (unproper fillup),
- thermostat (sticking),
- pump blade corrosion,
- and/or blocked radiator/system.
For thermostat check this page, your engine block system is very similar. Seek via 'Favorite Links' more infor for VQ http://www.cardomain.com/ride/748507/8
Engine overheats aaron_1971 Trans Sport 3 03-24-2005 03:57 PM
engine overheat? 89TX5.0 Mustang Talk 13 07-14-2004 12:51 AM
my protege engine overheat papo1702 323/Protegé/Familia/Etude/Allegro 0 06-28-2004 03:42 PM
Engine overheat NebDb Cavalier 3 12-29-2003 04:02 PM
Engine Overheat Nimbus Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 05-29-2003 07:07 AM
