Old 07-10-2004, 06:57 PM
89TX5.0 89TX5.0 is offline
Question engine overheat?
Well my old electric fan went out and I decided to use a flex-a-lite fan. Well everything was fine and dandy until a couple of days ago. It had overheated on the way to a mall. When i stopped radiator fluid was leaking and smoke everywhere. Its ok for like 10 min drives as long as I barely touch the gas . any ideas?
Old 07-10-2004, 09:44 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: engine overheat?
do u have a fan shroud?
Old 07-11-2004, 12:12 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
10 minute drives will overheat it again. I suggest ditching the flex-a-lite fan, and running a stock replacment steel fan. Then have the system pressure tested to see where the leak is.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-12-2004, 10:54 PM
no i dont have a shroud.
Old 07-13-2004, 01:33 AM
90Stangjc 90Stangjc is offline
Yes, defiently get a fan shroud. The purpose is to keep the air directly fowing to the radiator. Also ditch flexfan, its most likely not your problem but its annoying as all hell. I can hear mine over the exhaust. Your thermostat probably locked up on you, just get a new one or if its not real cold over there just take it out all together. The whole purpose of a thermostat is to get your heater warm faster. If you choose to put a new one in go ahead and get a 160 degree thermostat.
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
Old 07-13-2004, 08:19 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Where was the coolant leaking from? If your cooling system can't pressurize, it will cause the engine to overheat. It might be that your radiator cap needs to be replaced.
Old 07-13-2004, 09:28 AM
HiFlow5 0's Avatar
Stanger
NO, never run a 160 stat or remove it all together!!!!!!!!!!!!!!!!!!!!! This will cause the engine to run too rich and may actually make the motor run hotter, because of the constant cycling of the coolant at the low temp level. Coolant will keep cycling, either not allowing the engine to reach proper temp levels, or on very hot days, cause the motor to run hotter then normal.
I would only suggest a stock type 192* unit such as came with these cars. This will allow the coolant to dissipate heat longer in the radiator, before the stat will allow the cycling process again. Not to mention these motors/computer were designed to operate with it.
Another thing to check is to make sure the flax fan you bought is a reverse rotation fan, otherwise it will heat up very quickly. Again, I suggest running the stock fan and then having the system pressure tested.
-2013 Ford Flex
-1999 Ford F150
Old 07-13-2004, 11:31 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Re: engine overheat?
DAMN!
You beat me to it...
Old 07-13-2004, 12:07 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
A t-stat is intentionally a restriction in the coolant path... a restriction = pressure, pressurized water has a higher boiling point and can absorb more heat... pressure and therefore a tstat are absolutely neccesary in a water cooled engine!! If you don't want the fast warmup a tstat offers, get a restrictor plate. Do not run it open!
Old 07-13-2004, 04:26 PM
thnx for all the help, you guys really cleared out the whole thermostat thing for me.
Old 07-13-2004, 05:55 PM
Oh, sorry. I suggested that because that's what i have done to mine and its runs at a constant 150 degree's all the time after the initial 5 minute drive. Down here the weather varies from 60 degree's at night to 97 degree's in the day and it always stayes the same. I also have a 3-core radiator so that might make things diffrent?
Old 07-13-2004, 08:12 PM
HiFlow5 0's Avatar
Stanger
150* is WAY too cold!!!! Your car much run real rich and get shitty gas mileage.
-2013 Ford Flex
-1999 Ford F150
Old 07-13-2004, 09:04 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
What kind of MPG do you get? Like Highflow said it can't be good!
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 07-14-2004, 12:51 AM
Last time i tested it, it was around 9mpg. Yeah shitty. But i dont think that it could possibly get that bad, i think i tested it wrong. But i think it is a good bit quicker or at least it feels like it. Everybody i race or that see's me jump on it is like "there's no fuckin' way that cars stock!". But i dont know.......it is a mustang.....
