Old 06-04-2002, 03:17 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Sadly the floor pans of the 4WD and FWD models are TOTALY differnt.
Iv seen it done on a Lancer in Ausie, but the guy was a panel beater and had to buy a GSR Lancer, and weld the floor from it into his FWD Lancer coupe.
Far to much work for any normal person to even think about.
I dont know what models were avlaible in the US but in Japan there were non-Turbo 4WD models, which will easily take a Turbo swap.
However you dont get the bigger brakes and stiffer suspension of the GT-X or GT-R models.
A Rotary engine could be possibly. Theres a 13b powered Mini running in many local races here at the moment and doing quite well.
You would need totaly custom engine mounts. A suitable FWD G/box capable of handling the power (for the mini its a Toyota Corona 5sp), with custom axles to suit. And a custom adaptor plate between the engine and Box.
Then you have to worry about making the engine work. This means basicly a custom engine bay wiring loom. as well as a suitable fuel supply.
Its not really a back yard swap.
Old 06-05-2002, 11:01 AM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Not to mention a green 323 with a 20B I beleave?
Anywho, about the thread. Some mentioned the concern about gas consumption with a turbo. Just because you have a turbo doesn't mean you have to drive around on boost all the time. I think that considering the base engine forced induction would be the best way to go. I'm sure given the time and money one could hit your target HP figures leaving it N/A, but it would be less costly to turbo it. And once you add a hairdrier, there is a whole new field of tuning to get into... Hybrid turbos, remapping boost, all that good stuff :licker:
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 06-05-2002, 07:37 PM
cadet's Avatar
cadet cadet is offline
that's a good example of what can be done if you really want to. this car started out as a FWD 323. it now has a non turbo 20B driving the rear wheels, sounds cool and goes hard. as i understand it this guy's brother started making a FWD rotary 323 but it didn't get finished.
from what i understand the BP is pretty similar to a miata/mx5 motor, surely some of these have been worked as atmo's?
Old 06-05-2002, 07:47 PM
Moppie's Avatar
Master Connector
I dont know, they will be similar since both are Mazda engines, but visualy they look very differnt.
However that said, there are plenty of Turbo kits avliable for the MX5 (miata for the yanks) and Im sure it wouldnt be hard to make one fit a 323.
Old 07-21-2002, 09:48 PM
wight wight is offline
Us and Canada got some awd protegés. with the sohc 1.8 engine. a pretty rare car. as they are mated with the fm15-r tranny, a bpt swap isnt a good idea.
Old 07-24-2002, 02:38 AM
pimpin4profits pimpin4profits is offline
Send a message via AIM to pimpin4profits
Theres a guy running around where I live with a 323 with a Probe/Mx6 V6 swap. Thats a pretty damn quick little car...the guy has no interior save for two racing seats and mabye some speakers, im not sure. But regardless, its an amazing car.
Tranforming from family sedan.....to WRX slayer!!!
"Hey Riceboy, dont be mad at me because your car puts out more decibals then it does horsepower."-Me(I think)
"Don't like what I say, Well youre a hypocrit, Cause now youre givin me shit, for givin you shit."-Brad Holmes
Old 09-07-2002, 10:19 PM
AquaDave AquaDave is offline
Here's the real deal
It takes X amount of gas to move X amount of wieght at X speed.
no ifs, ands or buts about it
when hopping HP you must plan on
1- the engine will not run as smooth
2- you will use more gas
3- maintance quadruples
HP is no fun if you don't use it
A super or turbo charger is the quickest and cheapest major HP gain.
Either on a stock engine gives the biggest boost for the buck.
Old 07-07-2003, 12:49 AM
Ryan_310 Ryan_310 is offline
Send a message via AIM to Ryan_310
Exclamation
For anyone out that that has ever thought about using a turbo no matter how big it is may be it is not a fix to make your car fast and you cannot just avoid doing other work. There have been tests from two of the same cars on was stock and the other had a huge turbo on it. The car that ran the fastest believe it or not was the one with no turbo. Without doing other mods to an engine and just putting a turbo on will cost the same amount of money in the end if not even more because of things breaking and you could have to get rid of the whole engine by braking a rod. So in the sum of things you are better off to have other things done to your engine first and the last thing you should think of is forced induction.
Old 03-21-2004, 02:06 PM
jhillyer jhillyer is offline
Re: Question on Natural Aspiration
Originally Posted by SaabJohan
Why spend a lot of work and money on NA when you can get twice the power at the same price with a turbocharger.
Show me.
I can't get twice the power with turbo without twice the cost in fuel -- race fuel. Otherwise, it's whopping intercooler, water injector, and pump crap 91 octane, and maybe 20% power improvement at low RPM or mid-rpm high load, and finally 40 to 60% improvement at high rpm. I'm presently at 80hp/liter NA at 6200rpm, no gadgets, leisure maintenance intervals, and I get to hear my 5 valves per cylinder chop the intake air. A turbo obscures that beautiful sound. Anyway, I've a turbo on the other _broken_ car. <<< get it?
You're wasting time reading this, move onward to the next thread.
Old 03-23-2004, 09:29 AM
SaabJohan SaabJohan is offline
Re: Re: Question on Natural Aspiration
Originally Posted by jhillyer
Show me.
Add a turbocharger, lower the compression ratio a bit and modify the fuelsystem. With 1 bar of boost you should now have twice the power compared to the stock engine. How much would it cost to make the same power increase when keeping the engine NA? It wouldn't be cheap.
Most stock NA engines can handle boost pressures up to around .5 bar with stock compression ratio when an efficienct intercooler is used (the fuel system must of course be modified). A small drop in compression ratio would easily increase it up to 1 bar without the need for any racingfuel.
Spending the same money on a NA and a turbo engine the turbocharged one will easily have more than twice the power.
"There have been tests from two of the same cars on was stock and the other had a huge turbo on it. The car that ran the fastest believe it or not was the one with no turbo. Without doing other mods to an engine and just putting a turbo on will cost the same amount of money in the end if not even more because of things breaking and you could have to get rid of the whole engine by braking a rod."
Those guys that did that test have probably not made anything right, if there is any test at all. I know of engines which are turbocharged and the only thing that is modified is the engine management, fueling, compression ratio is decreased and a better head gasket is used, then a turbocharger and intercooler is added, with this the power output is more than doubled - on pump gas. Among others I can mention a BMW M5 engine (the old 3.8 inline 6) developing more than 700 hp with those modifications. What that will do for a cars performance needs no explaining.
Old 03-24-2004, 08:20 PM
Steel's Avatar
Steel Steel is offline
Show me.
Don't forget that that the power of the engine is directly proportional to the amount of fuel (air/fuel if you want to be technical) you're stuffing into it. Sure on an N/A you can port and polish the cylinder heads, stroke it, get in lumpier cams and all that. All you're really doing is getting more gas into those cylinders. A turbo does the same thing: stuffs more air in there so you can mix more gas with it and have a bigger boom.
And the reason that turbo's produce more power (generally) is becasue quite simply, it can stuff more air into the engine than the engine would be able to suck in itself. An N/A engine would be hard pressed to get positive pressure in the cylinders at BDC.
naturally aspirated and its potential revum131 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 51 07-25-2003 04:56 PM
?'s, keeping GSR naturally aspirated DCNo07 Integra 9 07-21-2003 11:32 PM
Turbo or Naturally Aspirated HondaCivic4358 Engineering/ Technical 6 05-10-2003 02:39 AM
Forced Induction vs. Naturally Aspired mrnabeehhasan 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 06-06-2002 04:32 PM
IS it possible to turbo the naturally aspirated 2jz-ge supra? xodus917 General 7 03-09-2002 08:56 PM
