Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-18-2003, 07:03 AM
revum131 revum131 is offline
naturally aspirated and its potential
sup guys...juss wondering if u could give me some advice. im soon to be getting a 95+ 240sx. i think i want to go a differnt route than the ka24de(t) or the sr20det swap. im thinking of goin naturally aspirated. so heres the thing i was wondering if there were any makers of a quad throttle body for the ka24de. i've been searching all night and i can't find any. also i would probably get high compression pistons, new rods, cam, rebuild my engine, ect. how much hp gains do u think i can get goin NA? also is turbo a cheaper and easier alternative? wat eles will i need to know about NA engines? Is there an other major NA engine component other then individual throttle bodies and high compression pistons?
thanks for ur help
Old 07-18-2003, 08:14 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
if yopu wnat over 300hp go turbo if you want less then 300 go n\a
i prefer turbo..
but thats just me
1
Shift_BOOST
97 s14
Old 07-18-2003, 01:43 PM
barrigaS14 barrigaS14 is offline
you WILL be spending alot of money on this. the n/a route is hard as hell. a guy in my club is going this way and has dropped about 5g's into his car and he says he is only making about as much as a stock SR. maybe a little more but not much. he also said he should have done the swap.
-cuz it's there
Old 07-18-2003, 02:09 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
ive spent 3500 and im running a flat 15.0, but mine's an auto
im thinking if its a stick i'd be running around 14.0. it's a lot cheaper than popping in an sr.
438whp / 373tq - 11.9 @ 126
Old 07-18-2003, 05:21 PM
nightwalker nightwalker is offline
Send a message via AIM to nightwalker
3500? an SR swap is the same price! ...and twice as fast
“Before buying the next go-fast part, invest in the most tunable component yet... the driver's mind”
Old 07-18-2003, 05:24 PM
yada yada yada
twice as fast as 14.0?? hehe sorry to say, you know absolutely nothing
an sr runs 14.5 with a real good driver.
Old 07-18-2003, 05:35 PM
sorry, you must be a really sorry driver or hang out with really sorry drivers. 5 friends. all SRs. two ran a best of 13.8. the other three run 14.2. Last time I was at CMI, a kid in a stock s13 SR also ran a 13.8 Done three SR swaps. All cars smoke GT stangs and Z28 camaros
Old 07-18-2003, 06:10 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
ok I'm looking for an estimated(or exact if possible) time for each of these set ups
KA24DE: add turbo, non-intercooled, manifold, ehaust, downpipe, intake
KA24DE: the above + intercooler and pipingg, BOV, wastegate, exhaust flange
SR20DET: exhaust, intake, downpipe, BOV
KA24DE: non-turbo, port and polish, pistons, cams, rods, exhaust, intake, downpipe
say they all have light weight flywheel with like a stage 2 clutch kit and a B&m short shifter and light weight tires and performance tires and abotu 1 1/2 drop with decent suspension(hopefully this gets rid of some variables)
also what about the 2 kits for the KA24DE they have here http://www.realnissan.com/faq.asp
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 07-18-2003, 06:30 PM
yada yada yada
what are you talking about
http://www.mrccfl.com/quartermile.html
2690 lbs
205hp (and that's a HIGH estimate.. most sr's have 190hp because of age and use)
also a pro stock driver took out a stock sr and ran a 14.5. i really don't know why you are making this up...... your friends must have short shifters and lightened flywheels. they are NOT stock
Old 07-18-2003, 06:55 PM
ok, more details ...when doing the swap, don't just take it and put it in. Obviously check for a motor that has good compression. If not, make it so. Clean clean clean. check all, or change if budget allows, vacuum lines. make sure no leak in pipes, and around stock intercooler. if everything is working right. e.g. clutch not fried, bad turbo, etc. 13.8 is attainable. 14.0-14.2 is more likely. I am telling you from experience. We tested at Sacramento raceway, so our elevations may be different from yours. Also, for the previous question, an SR swap shouldn't take more than three days. Two if you don't have to take the SR out of a clip. Easy swap. KA24de(t), I can't say, because I have not done any. My friends integra, which in my opinion is harder to work on, took only one day to put on his drag turbo kit. But depending on level of knowledge and experience, this obviously will vary (sometimes greatly!)
Old 07-18-2003, 09:36 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Actually Sr20 swaps are only 2500 bucks and 3000 for the front clips so that leaves 1000 or 500 in mods which would easly take out his N/A Single Cam.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 07-18-2003, 09:38 PM
Also you are not going to shave off a second in the 1/4 mile time just because it is a manual maybe .4 seconds.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 07-18-2003, 10:43 PM
yada yada yada
interesting you say that
everyone is telling me a stick is the ULMIGHTY GOD of the racing world. .4 sec aint that much.... i thought it was .4 too but a lot of people tell me it took off a full sec
Old 07-19-2003, 10:42 AM
Towlie's Avatar
Towlie Towlie is offline
Send a message via AIM to Towlie
LMAO 3500 to run 15
hehehe
if i spent 3500 i better be in the 13's
I ran 15.7 with a crappy exhuast, faulty clutch that was going out and bald tires
I figure put some low pros on it, the clutch was just changed
get the cold air intake, better exhuast, some headers, ported and polished i can get done for 200 on the head, or sometimes I see head withs high compression pistons for like 100-200 on ebay sometimes, and that leaves u wti a lot of money for misc mods wherever the fuk u want, u could even get some spray with that LMAO!
The only reason I would do an sr20det swap is because i have 150k miles
but even than, if im gonna spend that much money on a swap, ima just save up and do a 350chevy swap :-D VRRRROOOOOOOOOOM!
Wanna get high?
Dont forget to Bring a Towel!
Towlie is off the wang wang!
Asshole Krew Member #004 We are 1337 RoXxoR and OWN JOO!
Old 07-19-2003, 12:30 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
350 in a 240sx........
hmmmm how about an old 327 or z28 302, that would be badass if you had to have a CSB. Getting a northstart to work would be badass, 300hp and that thing likes to rev, one of the best v8's I've abused.
if your gonna do something different, do something different...
so sick of hearing about 350's.... it isn't the end all engine and a 327 or a 302 will whip its ass and is a better engine for a road course.
Natural Aspiration At Its Finest Mercad Off-Topic 30 07-29-2004 02:07 PM
Natural Aspiration Returns with new Generation S-class and CL TheScientist General Discussion 1 05-21-2004 12:54 PM
Question on Natural Aspiration CAptynCrunch Engineering/ Technical 25 03-24-2004 08:20 PM
Forced Induction vs. Naturally Aspired mrnabeehhasan 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 06-06-2002 04:32 PM
IS it possible to turbo the naturally aspirated 2jz-ge supra? xodus917 General 7 03-09-2002 08:56 PM
