Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-07-2001, 01:16 PM
phaqgm phaqgm is offline
Send a message via AIM to phaqgm Send a message via Yahoo to phaqgm
Originally posted by morpheusxiii
phaqgm, what do you think of the reversed engine design?
You know, I haven't given it much thought. I can tell you this though. It isn't that bad. It makes it harder for companies to develop a header (I am working on one). I guess there really aren't too many downsides, or upsides to the engine being the way it is.
One good thing though, like you mentioned is that the intake manifold can stay a little cooler, and the airbox pulls air right from the little grill Also, the path that the air has to travel is less, therefor it doesn't gain much heat along the way. Those are really the only things that I can come up with right now. Let me get back to you after lunch
Old 08-07-2001, 08:46 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Seesh, I complemet the celica and Toyota's engine building skills and you throw it back at me.
By comparing the Celica with the Type-R I think your paying the Celica a huge compilment, like you said the Type-R is hand finnished and made in very limited production numbers. While the Celica is mass produced, (although here the Type R has better sales) and the only real comparision with the celica is the GSR/VTiR/SiR Integra, whick in the US is not as fast in a straight line as the Celica. (The USDM GSR is a little slow, we get the JDM cars here.)
Iv never driven a new Celica, But I know ppl who have, and they all mentioned that the ratios dont quite match the engines power band. Basicly the Second set of cam lobes are to aggresive and engage to late, this is something Honda had trouble with when developing thier First VTEC engines for bikes, and something Mitsubishi had trouble with on the first MIVEC engines. Give Toyota a few years more to do a little more R&D and the problem will be solved, and they will have an enigne as good as anything Honda can produce. However it currently lacks the life of the 11 year old B series engine, just like Hondas ZC (non-VTEC DOHC) lacks the life of Toyotas nearly 20yr old 4age.
As for the fact that the celica comes with factory headers, well so what, My '90 SiR Civic has factory headers, and so does my mates 4agze powered '89 MR2, its something that most manufactors have been doing since the late 80s, early 90s and is nothing new.
Its a cheap way for the manufactors to regain hp lost to emissions control.
The placment of the cat closer to the exhaust ports has little to do with the way the engine sits in the engine bay, Honda have been doing this for years with the d seried engine in the Civic, and many european cars have also been doing the same thing, it does make aftermarket headers a little difficult, but its likly that the stock design is so good (its a Toyota remember) that after market headers wont give you any gains unless your changing the cams as well. I know several people ralling the 4age and all use the factory headers, as after market ones have often shown a drop in hp.
The celica is a great car, I never said otherwise. Its just that its something Very new for Toyota and as a result could use a little tweaking, just like any new car design from any manufactor.
Old 08-08-2001, 05:21 AM
Morpheus XIII Morpheus XIII is offline
phaqgm took the words right out of my mouth. The only thing I can add about the engine layout matched with catalytic converters is that the superheated cats (which agreeably perform best when placed as closely as possible to the hot exhaust ports) stay away from the radiator, which is working to dissipate heat itself. As phaqgm stated, heat is not a problem. I've seen much worse underhood heat ailments on the long-nosed Supras.
And another thing, when did the whole Type-R issue come up? I never compared the Type-R (or the GSR) with the new Celica. I was talking about the numerous similarities between the new Type-S and the GT-S, as well as the one main difference: displacement. BUT, if you do want to compare apples to apples, try dueling the Type-R and Sports M. As I've said before in the GT-S thread, both are limited production high-sports models, but the Sports M retains some of the valuable creature comforts (if someone want a lighter car they can just remove the excess; it's not that difficult). Purpose built race car? That's a real load. The majority of the Type-Rs here are on the streets. I'd rather have the standard a/c and navigation system while cruising.
Originally posted by Moppie
There's also the problem of the exhaust making a sharp bend to get away from the egine.
Take a look at the piping; it never makes a sharp bend anywhere. Perhaps the older makes you previously mentioned had them, but I just don't see it. It has two major angles in the engine compartment, just like the two on the front mounted headers, but it actually flows much more progressively since it doesn't need to clear the bottom of the transmission, which the front ones do. Furthermore, with the less hardware under the engine/tranny, the designers have been able to lower the position of the engine, reducing the center of gravity.
There are other factors, such as tradition, the old way worked so why bother changing it?
We all know the phrase, "If it ain't broke, don't fix it". Well then there wouldn't be any advancements in technology. If Honda wasn't out trying new methods, there wouldn't be a B18C. While on the topic of 'comparisons', I applaud new ideals and thinking, and am glad that Toyota has raised the bar, which has been set by Honda for so very long. As we all know, many of the japanese sports cars have been focused around turbocharging, minus Honda. Now they will be receiving some much needed competetion in the natural aspiration department.
I cant see any real advantages, other than easier access to the intake side of the engine for servicing.
Try to be open minded. Besides the aforementioned cures for heat concerning the radiator, and intake heat transfer, think of forced induction possibilites. Right now, my mind's eye is sketching an visual of a turbo nestled back by the firewall, drawing in air from the larger Sports M's hood scoop, with a nearly straight downpipe exiting to the rear.
If Honda inline fours are your thing, you should accept this engine layout--the new Integra/RS-X DOES use it, as well. With the 20-year experience you continue to refer to, it seems funny how Honda is forming their future i-VTEC powerplants with characteristics from Toyota.
Old 08-08-2001, 05:22 PM
gang$tarr's Avatar
gang$tarr gang$tarr is offline
I don't like how that nose looks :apuke:
Old 08-09-2001, 08:20 PM
The nose:
Yes, it's extremely different and something that no one has ever seen before. But people shouldn't simply brush aside what's new and stick to the same old styles. It's impossible to know what is going to become the next standard, so people should try and stay open minded about what the industry presents. This particular front bumper seemed a little radical at first, but now the wild design is settling in. Remember Veilside, with their highly revolutionizing designs which FAR too many aftermarket companies have ripped off? That is the impact that styling can produce.
Old 08-11-2001, 10:33 PM
Nxtyoung Nxtyoung is offline
First of all i have to say I love the car. I live in colorado and big car shows are onething we dont have. We have te tri staeauto show but no concept cars are displayed so i am stuck looking and the photos of all the good ones on the net. I remember i was looking at all the cars of this last Auto show in LA and stumbled on to the pics of the Celica; three words, Creamed my Pants. The Celica in my mind is the perfect car. it combines speed, handaling, reliabilaty, comfort, and well it dosen't look half bad. ever since i bought my 87 i have been hooked. once again the car is one ofthe best i have ever seen.
Old 08-12-2001, 07:12 AM
Moppie's Avatar
Master Connector
morpheusxiii
Please reread my posts. I never said anything bad about the Celica, or Toyota engines for that mater. In my mind the Toyota 4agze is the best 4cly to have ever come out of japan followed by the Honda B series engines. I own a B series powered car and im building a 4agze powered kit car. Why not power the kit car with honda? I believe the 4agze has far more potential and is easier to work on and with.
I compared the Celica engine with the Type-R engine becuase its the only other engine out there that is in any way simlar, and it is certainly suprior, but its also been around a lot longer, as Iv said twice now give Toyota a few years and they will be as good as anything Toyota can make. (I never compared the two cars, the diffrence come down purly to personal choice)
To acuse Honda of copying Toyota with the new I series engines is just silly, after all didnt Toyota copy Honda First, or was it Henry ford copying Mr Benz by making a car with a piston engine.
All the manufactors play follow the leader, and they have been doing so for over 100 years, its nothing new.
I love the new Celica, Toyota went to long with out a sutible sports coupe, the old Celica model was just to heavy and to slow. The new one is a revelation, I would choose it any day over a GSR teg, but would choose a Type-R for the reasons you pointed out, I dont care about A/C and sat nav.
Now about the placing the intake at the frount and exhaust at the back.
I will repeat what I said earlier and add a little extra to aid your understanding.
Its nothing new. Many other companies including Renult and Citron have been doing it for at least 15yrs, The fact that Toyota and Honda have just caught on shows how far behind the Japanese are in terms of some technology, (while the lack of things like VVTi-L and VTEC shows how far the europeans can be behind).
There are several reasons it was never done before.
-Heat insulation around the exhasut manifold. As I said earlier many of the early Renults had trouble with heat getting into the passanger compartment, and wiring looms etc.
-The cost of manufactoring manifolds and piping in the required shape, and thier effectiveness.
Modern design has clearly got around these problems, allowing the manufactors for what ever reasons to run the exhuast manifold out the back of the head, and not round the frount.
(and they clearly have thier reasons, but unless someone knows one of the designers and accountants, we can only ever speculate)
I can think of few real world benefits, lowering the engene hight is one I didnt think of, and is a good one, but remember you still have issues with Driveshaft and diff placement. (think about where it all sits relative to where and exhaust runs).
There is often plenty of airflow up the back side of an engine block, and depending on the shape of any underbody panels it can be as much o more than your getting in the frount through the grill.
(EG S/C and Turboed MR2, Air is forced from underneath the car and out the top of the engine cover vents, and same thing happens on the Mitsi EVO's and the Subi WRX)
If however its as you suggested to keep the super heated cats working at a nice high temp, then how is your lovely heat hating Turbo going to run? There isnt going to much of a temp diffrence accross the exhasut turbine, and those bearings are going to need a lot of oil to keep them cool, and you still have to worry about piping it into an intercooler.
The only possible advantage I can see is it means the engine can be set further back to aid in weight distrubution, and you can use longer intake runners with a larger and less restrictive plenum chamber or Air box. However it means a corosponding loss of room for larger exhaust headers, and a Turbo install.
Its all about compromise, and for the next generation of Honda's and Toyotas it looks like they have chossen to compromise on exhuast for access to the intake. (remember that Toyota especialy has possible the worlds best Factory exhaust manifolds, I plan on using one on my engine.)
Thank you.
(now please read it again. )
Old 08-13-2001, 05:20 AM
...as you should reread mine. I never proclaimed that you stated anything "bad" about the discussed topics. I started by simply making a comparison between the displacements of the 2ZZ-GE and K20C, and how identical they were other than the size factor. Everthing else was a response to a response.
I compared the Celica engine with the Type-R engine becuase its the only other engine out there that is in any way simlar, and it is certainly suprior...
Once again, an engine more similar to the one in the Type-R is the one from the Sports M.
To acuse Honda of copying Toyota with the new I series engines is just silly... ...All the manufactors play follow the leader...
No one is acusing anyone of anything, and "follow the leader" is pretty much the same thing I was referring to:
...Honda is forming their future i-VTEC powerplants with characteristics from Toyota.
Furthermore, some clarification about the new 'layouts':
Excerpt taken from Sport Compact Car: Features - RSX Type-S
"The two models [K20A, K20C] have completely different cylinder heads, sharing only the basic layout. Even that basic layout has changed from the B18, with the intake now on the front of the engine, and the exhaust out back. The rear-mounted exhaust allows the catalytic converter to be moved slightly closer to the exhaust ports without requiring a true-close coupled layout (with a front-mounted exhaust, the catalyst at this distance would end up under the oil pan, where it would heat the oil and cause ground clearance issues). The exhaust routing is similar to the new Civic and to Toyota's 2ZZ-GE Celica GT-S engine, with a short, low-mass tubular stainless-steel four-into-two manifold followed by an "e-pipe"--basically a large single pipe with a divider wall down the middle--in place of traditional secondary pipes. The e-pipe design reduces surface area so less heat is dissipated to the outside air. Heat loss is further reduced by making the outside of the e-pipe double-walled. All these low-mass, double-walled, low-heat-loss games are efforts to speed catalytic converter light-off. It obviously works, as both models meet strict Low Emissions Vehicle Level II standards."
--Dave Coleman
I am becoming slightly vexed by all that we have said. From this point, I will wait to respond when I have further data concerning our discussion, or reply when any of you have the same.
Old 08-15-2001, 07:57 AM
Moppie's Avatar
Master Connector
Cool, man.
There has to be some reason why its done, and there is deffinitly some reason why it wasn't done before. Manufactors arnt inclined to make radical changes to designe unless is there is the possibilty of a benefit. However what that benifit is could be anything, from easier faster serviceing, to more effeciant better working cats, or some cobination of a whole ot of diffrent factors.
I have an ask at the Honda NZ service center next time im there, there service manager is nice guy, and has been working for Honda for about 15yrs. It could be intresting to see if he has anything to say.
Old 12-17-2001, 10:40 AM
M Spec M Spec is offline
Back onto the orignal topic!
Hi everyone, new to this board.
Hmm, the Ultimate Celica was built as a promotional tool to generate good PR and interest in a the Celica. I think they have done a good job. The use of the turbo drive train and engine from the all-trac was more to do with reliable package and creating a buzz for sports car enthusists.
The 2ZZ-GE is a good engine, but the all-trac makes the car more exciting and gave it more impact, specs and performance wise. I think the amount of exposure the Ultimate Celica has paid for itself off in terms of cost to produce the one off special. I believe the car was built as a marketing tool and added street cred as well but to also encouraged potential new Celica buyers to the cars potential given the all-trac drive train/engine combo.
Hopefully the TRD NA engine package from Japan will be released sometime next year for the 2ZZ-GE. It is claimed to increase power to 230Hp.
Jason
Old 12-17-2001, 08:42 PM
Have you a link where I can see more about this TRD NA engine package in Japan?
Old 12-18-2001, 04:01 AM
F20C's Avatar
F20C F20C is offline
How about the Celica Turbo shown in Japan? 200 bhp and 260 N*m torque. That would make it 200 bhp and 188 lb.ft torque.
http://www.toyota-stars.ch/Berichte/...n2001-Silo.htm
Old 12-18-2001, 06:19 AM
F20C, thanks for the info and pics.
If you look closely at the engine it is only VVT-i on the engine cover. It is the 1ZZ-FE engine found on the new corolla, MRS and lower spec GT celica found in the US market. This engine stock is rated at 140hp. So what your saying is correct about 200BHP, thats a impressive jump in power.
Looking at the web address, that car is not in Japan but in fact Europe. Looks like probably Germany to be more precise. It has also the TTE bodykit and wheel combo on it was well which adds more weight to my assumptions. Does that mean TTE has a turbo kit they are developing for the European Celica? very interesting.
Morpheus XIII, I'll see whay I can do. The site is Japanese with very little info. but with pics of the parts. I'll try to find it for you. If you go to www.toysport.com, they prematurely listed it on there website for the 230HP TRD Jap spec 2ZZ-GE. So the kit is real. I sure it consists of new inlet and exhaust camshafts, header, valve springs and higher compression pistions.
Jason
Old 12-18-2001, 11:58 AM
F20C's Avatar
M Spec
TTE is like TRD for Europe. The same company that drop a 4.3L V8 Kompressor into IS300.
Old 12-20-2001, 05:24 AM
F20C Thats but of an understatement,
Thats like saying Prodrive (U.K) is similar to subaru's STI operation in Japan.
I know what you mean though.
Morpheus XIII, here are some links to some Japanese pics of the kit. Sorry they are a bit uncelar though. (out of my control)
http://www.page.sannet.ne.jp/hiron/celica/as01.jpg
http://www.page.sannet.ne.jp/hiron/celica/as02.jpg
One thing for sure is these parts are destined for the 2ZZ-GE.
Jason
2ZZ-GE really that great? Morpheus XIII Celica 28 07-27-2009 07:02 AM
nos on the 2zz-ge? marlborocowboy82 Corolla/Matrix/Voltz 0 07-17-2004 07:18 PM
Can I fit a 2ZZ-GE engine in a 1ZZ-FE Celica? g7celica Celica 0 06-14-2004 12:12 AM
Turbomanifold for 2ZZ-GE MKIISupra Celica 2 01-04-2004 01:22 PM
3s-ge & 3s-gte bobo_80 IS200/IS300/IS350/Altezza 0 07-19-2002 02:12 PM
