Old 06-08-2005, 10:53 PM
SPEEDERZ SPEEDERZ is offline
Re: COMPLETED: Tuned WRX *Beware 56k*
the painting isn't bad...the interior i can't understand the golden color in fabrics...but it's your choice...
Old 06-08-2005, 11:02 PM
druid_99's Avatar
druid_99 druid_99 is offline
Re: Re: COMPLETED: Tuned WRX *Beware 56k*
Originally Posted by jswillmon
Here's a tip.
When using putty, don't pile it on and then try to shape the hood from the pile of putty. Use styrene strips to get the basic outline of the shape your going for then add just enough putty to fill the gaps or add the right curve to the opening in the hood. When you add putty a little bit at a time you can smooth it out while it's still wet and then you don't have to sand for hours.
If I was you I would not spend anymore time sanding the hood, just learn from the mistake. You could sand on all that putty for years and It will always have lines and indentions. Save your CF for the next model. Just keep at it, each model will be better than the one before.
Ps... Think you could make the pics a bit smaller?
I agree. For me, I usually make a basic outline shape using styrene before applying any putty. Less putty is better as you can add bit by bit to get the desired shape rather than put a lot and waste most of it trying to get the desired shape.
Are you using the green putty by Squadron? I'm using the white one and I have no problem with it. For small gaps I usually mix it a bit with industrial thinner to make it softer so that it can get into it. I usually apply bit by bit using a small flathead screwdriver dipped in thinner (wierd huh? but I usually do it like this and it works!).
I suggest you to save your CF decal for other builds and try to correct the hood (if you want to). Just my suggestion.
Other than that, I think your build is good. Not favouring the gold though. Need to do the window trim. Overall, a good try.
P/S: Is it the picture or lighting or is it me because the rear hood looks a bit rough.
What is understood need not be discussed
Old 06-08-2005, 11:29 PM
{(itchy)}{finger} {(itchy)}{finger} is offline
Send a message via AIM to {(itchy)}{finger}
your car
green putty sux first of all... its the crappiest stuff ever... stick with tamiya even tho it cost 2 to 3 times as much... quality is 500% better... n' i think you mixed teh green putty with water.. n' thas why its all clumpy...you'll improve next time.. nice subaru tho i always wanted to make 1
~nate
Old 06-08-2005, 11:49 PM
visible33's Avatar
visible33 visible33 is offline
Send a message via MSN to visible33
Interior painting looks a little disorderly ( gold places ) and on the rearward hood are some notch.
But all over details is nice.
Old 06-09-2005, 10:27 AM
Whumbachumba's Avatar
Whumbachumba Whumbachumba is offline
The trunk lid is wierd because I was going to make a duckbill type spoiler, but I ended up giving up and I had to sand the putty dowm on that also.
U shouldn't customize your first builds...you should wait until u have more experience...
First off, this isn't my first build, this was my first time at puttying.
Once again, thanks for all the comments, I'll try to get one of my in progress builds up now that the camera's back home from my parents trip to LA.
Current Project: '70.5 Camaro; Air-Cooled GB: '66 Beetle; Shelby 427 Cobra
Old 06-09-2005, 01:39 PM
kallum kallum is offline
yes all that is right that hood is a bit buggered
Old 06-09-2005, 04:27 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
dAng ! Can you say..."I love gold!!!"
Oh and the whole...
Originally Posted by Whumbachumba
I just did the gold because I wanted to have that hispanic/ricer/high class feel all in one.
Isn't too funny
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 06-09-2005, 05:18 PM
Well, being from South Texas where "everyone" is hispanic, I found it somewhat fitting, but if y'all don't like that reference, then ignore it.
Old 06-09-2005, 05:29 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
All I can say is wow. You exceeded your Putty skill by a long shot. That was a gross amount of putty on that hood.
None the less, good for a novice.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 06-09-2005, 05:37 PM
ThePerfectGetaway's Avatar
ThePerfectGetaway ThePerfectGetaway is offline
Send a message via AIM to ThePerfectGetaway
Okay, let me first say, take it easy on the putty. Second, did you sand the hood at all? Did you even paint the car? It doesn't look like you did. And you need to take it easy with the gold paint pens, sharpies, whatever it is. Sharpies do not make the world go round my friend. The hood just needs some work, and the interior, get rid of the gold insets, gold headlights, gold license plate section, & gold foglamps. The gold rims look good on a WRX. Sand the hood a lot until that bad boy is smoooooth, then you paint. But you know that. I ain't dissin' you, I'm just saying, it needs some work. The funny thing is, not to be mean, but, I've seen a hell of a lot worse... I've seen widebody kits extend from New York, to China. And they weren't even smooth!!
'70 Chevelle SS 454: In progress
Soon to come...
  • 1966 Volkswagen Beetle
What's going to be done to it? Oh, you'll see..
