Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-09-2005, 04:33 PM
ace395a ace395a is offline
Check out the subject "Wind noise fix" just a little further down in this forum. I think this should help you solve the problem. This particular problem and fix doesn't seem to be in the dealer system yet.
  #17
Old 03-09-2005, 10:45 PM
Papaw Papaw is offline
Re: Re: Re: Re: Re: Re: 2004 Venture wind vibration sound from under the hood.
Originally Posted by Papaw
I just got my car back. There is a new bulletin # 02-08-58-005B that was issued 2/08/05 . I saw a diagram but con't understand it. The work order says "Seal Body seam under Cowl" Have your dealer check that bulletin. I drove my car and didn't hear the noise, but I didn't always hear it. It depends on the wind speed and direction.
Good luck
Well, I drove my car today in strong wind coming from the west. When I turned toward the west the nosie came back, but it was steadier than before. When I turn the windshield washer on it will stop for at least a 30 min.
  #18
Old 03-09-2005, 10:50 PM
Re: Re: Re: Re: Re: Re: Re: 2004 Venture wind vibration sound from under the hood.
I got the following message from another person that I have had some info regarding this issue. I will check it out and thought you might want to also.
  #19
Old 08-10-2005, 12:26 AM
mikstevin mikstevin is offline
Originally Posted by rboatwright
Cool. Yeah let me know how it goes, then I will take the info to my dealer. Has your venture ever just stalled at a stop?
My venture has stalled on me approx. 6 times. Most of the time it happens when I am turning into a parking spot and it has stalled a couple of times as I am cruising to a stop. My venture is a 2004 and my dealer says to me that because it is not a consistant problem they can not do anything.
I can guarentee that when my lease is over I am done with this van.
  #20
Old 01-31-2007, 08:58 PM
rmw1947 rmw1947 is offline
I recently blocked off my rad completely with a house for sale corrugated plastic board ( it was very cold inside )and the noise stopped even at 80mph. i believe it stops air from entering at rad and exiting just below windshield at the seal between cowl and just below wipers. vibrating noise may come from seal or wipers. i too tried everything but gave up then stumbled on this by accident.in the summer will drive with wipers at 12 position ( pull the fuse ) to see if it is the wipers.
  #21
Old 02-01-2007, 01:01 PM
cjstew4 cjstew4 is offline
My 97 sometimes stalls when I come to a stop (every 4-5 months), but mostly when it's a quick stop. It stalls more often ( 2-3 months) going down this big hill from my house at the bottom going about 35-40 mph curving left as I am braking, but not always when I am braking. I just shift it to NEUTRAL and restart it, put it into DRIVE and proceed.
  #22
Old 07-21-2007, 03:34 PM
richfitch richfitch is offline
Good luck
I suffered this problem with my 2003 Venture until I noticed a rubbing problem with the back wheel cowling on the passenger side. I had to put in a screw to avoid rhe loose cowling and a wonderfult thing happened. The high pitched squeeling went away. So check the cowling arounf the tires as it may be the problem.
  #23
Old 07-21-2007, 08:41 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
richfitch- Welcome to AF ! Please check the dates of the threads and try not to resurrect those over 3 months since the last post date. Feel free to start a new thread if you have some new information to add. You can even link to the old thread if you feel it is applicable.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
