Old 02-18-2002, 07:06 AM   #16
flyonthewall
Car Mod guy
flyonthewall's Avatar
I could do some drawings if u wanted? theres not that much to it really! I copied the typical spray booth design (ie not just a box shape!) from a picture of a Micro-lux model in the Micro-Mark catalog. My version is 2ft wide and about 14inches tall, the side walls tilt away from the front edge so the top is narrower than the bottom and there is a bathroom extractor fan fitted in the top piece. The whole thing took about 2hours to make from design to the final screw!!
flyonthewall is offline   Reply With Quote
Old 02-18-2002, 07:24 AM   #17
awaken1973
Send a message via ICQ to awaken1973
have a pics how it looks?
Current project: Tamiya Porsche 959, red
awaken1973 is offline   Reply With Quote
Old 05-19-2003, 08:56 PM   #18
ljrlude01
Send a message via AIM to ljrlude01 Send a message via Yahoo to ljrlude01
Would this compressor be enough? or would I need something better, I'm also ordering an Airbrush Aztec Model A4709.
http://4toycars.com/index.cfm/fa/pro...ProdID/181.htm
sorry to bring this old thread back but I read in the FAQ is better to bring thread back to keep it in the same topic
01 Boosted Prelude
90 Nissan Skyline GTR
Mi-4
"current projects"
92 Honda Prelude,Ballade CRX
"finish project"
Skyline R34 GTR
ljrlude01 is offline   Reply With Quote
Old 05-19-2003, 08:59 PM   #19
Jay!
Horizontally Opposed
Wow, I didn't know Testors had one... Wonder who makes it for them...
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
Old 05-20-2003, 01:18 AM   #20
ljrlude01
So will this work or not?? should I look for something else? Those anyone have one of this compressors?
01 Boosted Prelude
Mi-4
"current projects"
"finish project"
Skyline R34 GTR
Old 05-20-2003, 02:35 AM   #21
008
008's Avatar
Looking at this http://www.testors.com/catalog_item.asp?itemNbr=12 ...
At 20psi max you're at the bare minimum. It also looks like it's preset at 20psi so you're stuck with that. No in-line filter or regulator, bad idea IMO. Some paints like acrylics need 25psi or higher or the nozzle starts clogging up with high paint flows, like you would need with a glossy car finish. When airbrushing tiny parts on a sprue using my Aztek I turn the pressure down below 20psi so I don't waste paint.
That compressor seems too beginner-ish or for small jobs like figure painting. Add in the cost of a regulator and moisture trap (about $30 for both) you could've bought something better. What are your noise limits? You could get a good unit from a department store for about $150 if you can live with the noise racket. But with a storage tank the noise would be intermittent as you can just fill the tank and spray with the compressor off. For example, Micromark has this that'll do the job and then some. The high-end Testors AC200 or something similar is your best bet for airbrushing cars. It'll do 25psi plus it's got a regulator and moisture trap. "Under load" is with the airbrush on, meaning it can keep up 25psi as you hold the trigger down.
Don't skimp on compressors, get what you can afford. If the next upgrade is $50 beyond your budget, wait and save the $50. You'll be much happier in the long run. I went for a 7hp 80-gallon unit but airbrushing isn't what I initially bought it for although I can airbrush all week with the tank filled.
008 is offline   Reply With Quote
Old 05-20-2003, 02:53 AM   #22
ljrlude01
I'll go shop around for something like the micromark, as far as noise goes I'll be doing this on my balcony on the 8th floor doubt I'll have problem as far as noise goes unless is terribly (sp) loud. Thanks for the tip. I'll post pictures of what i find here, kinda hard since I just move to japan and not sure where to start.
01 Boosted Prelude
Mi-4
"current projects"
"finish project"
Skyline R34 GTR
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 05:45 PM
Airbrush Compressor Question fullbloodchop01 Car Modeling 7 08-07-2003 03:30 PM
AC compressor question, need answer ASAP CRXtc '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-31-2003 08:51 PM
Compressor Question...... rcmaxx Car Modeling 1 06-18-2002 09:49 AM
Compressor Question JE123 Car Modeling 4 03-26-2002 10:25 AM
