#16
damn, im really confused now, they need to have this damn question on myth busters or something. LOL
#17
Re: does wut kinda gas u use matter?
Just put in whatever the manufacturer suggest with your engine...
As people have already stated, higher octane only allows for a higher compression ratio. |
#18
in my manuel it says "use unleaded gasoline with a pump octane rating 87 (research octane number 91) or higher must be used in your hyundai." so wut kinda gas should i use?
-[I belong in tard farm]- |
#19
stick with 89 octane and your fine
#20
Jeeze. It's a Hyundai. A economy car designed for low octane. Don't worry about it. It wouldn't be an economy car if it ran off of high octane would it? Wouldn't be very... economical.
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#21
the car is ptety fast tho. ok so it wouldent mater if i used high octane?
#22
this thread shocks me...
if it says use 87, then use 87. if it's designed to run on low octane, it won't run beter; as the engine is not designed to use a higher octane mixture. the biggest issue is the detriment that using low octane in a higher octane required engine will have on performance (and engine life).
hello, i am Dan No more project cars. I wonder how long that will last... |
#23
Re: Re: does wut kinda gas u use matter?
its un-needed and can actually end up hurting ur motor as well as ur wallet. there is no need to use it, so why do it? like others have said, read ur manual and use wut it says.
2003 Infiniti G35 99 Yamaha YZF-R6 (sold) 2000 Acura Integra Type R (sold) 1994 Acura Integra GSR (retired/sold) |
#24
Man, hes gotta be the first person I have ever seen WANT to put in High Octane...
2006 Redline Red Nissan 350Z Base K&N|Falken I am just that JDM tight, yo.
#25
A higher octane gas can resist more compression before it spontaneously ignites. So with a higher compression engine, either static compression or dynamic from boost, a low octane gas can end up igniting during the compression stroke, called detonation, or pinging, or knocking, etc. So you use a higher octane to keep it from detonating until you want it to, during the combustion stroke that is. If your car isn't knocking, there is no reason to run higher octane. In short, for your car, save your money and burn the cheap stuff. What does octane mean? |
#27
ok, i didnt realy understaind wut my manuel said. it said i can use high octane 2 i think,lol. ima just use 87. well my hyundai is fast,lol
#28
ya i do here pinging sometimes
#29
then RETARD your timing
#30
do wut,lol
