Old 04-07-2004, 12:16 AM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
Re: Ford False Advertising
I want to clarify my above statement...
If your car dynoed at 257, it means that it has significantly more than 275 at the flywheel, which therefore means that the manufacturer underrated the engine's output.
Welcome to the Revolution
Old 04-07-2004, 12:31 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I agree , 257 to the wheels on a 6 speed car usually means you have somewhere around 289 at the flywheel
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 04-07-2004, 10:50 AM
fajita23200 fajita23200 is offline
Re: Re: Ford False Advertising
Originally Posted by FormulaLT1
96 - 97 where rated at 285 Horsepower do to the exhaust change but most lt1's are under rated and do provide the rear wheels with somewhere around 250 horse's most find that LT1's actually put out between 285 -295 horsepower to the flywheel
I have heard before that the 93-95 Camaros had 275 horses,but I also heard in 96 they changed some computer components,not sure which ones .Once again this is what I heard(in no way to be confused with facts),The changes resulted in 310 horses.
This above all:To thine own self be true,and it must follow,as the night, the day,thou canst not then be false to any man.(William Shakespeare)
Old 04-07-2004, 12:32 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thats true that is the year they went to OBD 2 but with all the same sensors except the knock sensor. Also the 95 model year California F-body LT1 had OBD 1 but with the Exhasut mod and was producing the same exact dyno resulted as OBD 2 cars, They both have the same factory setting and sensor's the only change is do to government regulation to have a universal diagnostic port with standard trouble codes. And I wish they produced that many horse but like I said all I ever heard was 285 - 295 at flywheel
Old 04-07-2004, 03:29 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Re: Re: Ford False Advertising
the 97 z28's also had aluminum heads, which also resulted in more hp. not sure if the 96's had aluminum heads, they might have...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 04-07-2004, 03:56 PM
FormulaLT1's Avatar
Fight the powwa!!!
All LT1 F-bodys and Vettes had Aluminum heads and all LT1 F-body's are within 10 Horsepower so no year has any real advantages over any other except 94 -97 have a advantage in my opinion because of the larger injectors used and the new computer setting's that where used with Mass Air Flow system but other people have disputed me so that argument can go either way
Old 04-07-2004, 03:59 PM
All LT1 F-bodys and Vettes had Aluminum heads and all LT1 F-body's are within 10 Horsepower so no year has any real advantages over any other except 94 -97 have a advantage in my opinion because of the larger injectors used and the new computer set's that where used with Mass Air Flow system but other people have disputed me so that argument can go either way
i know for a fact that some of the early lt1's had cast iron heads, i've seen them. and i am 99% sure that it was a special thing that the last of the lt1's had
Old 04-07-2004, 04:00 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Originally Posted by 94CamaroZ28
1.1 under the advertised horsepower, but don't get a refund because of that. Get a refund cause its ugly and slow.
My, you're not biased are you
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 04-07-2004, 04:05 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'm sorry but I have seen alot of LT1 and have read alot of LT1 facts and talked to alot of LT1 driver's and your wrong the only LT1's that came with Cast Iron heads where the one's used on Caprices and Impala's every Formula,Trans Am, Z28 , Vette came with Aluminum, Infact there was even a thread on it
Old 04-07-2004, 04:12 PM
FormulaLT1's Avatar
Fight the powwa!!!
Read the first 2 sentences from this site and you will see that they all came with Aluminum heads.
http://www.h-body.org/people/project...on-LT1SBC.html
Old 04-07-2004, 04:20 PM
MarxZ/28 MarxZ/28 is offline
I believe in 96-97 you could get 305 horsepower with the z/28 SS i got a 97 one
Old 04-07-2004, 04:25 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thats true the WS6, Firehawk & SS all had 305 Horsepower but I was just comparing the base models
Old 04-07-2004, 08:31 PM
94CamaroZ28's Avatar
94CamaroZ28 94CamaroZ28 is offline
Send a message via Yahoo to 94CamaroZ28
I also heard that '94 is the last year before they started putting govenors on LT1's. I think this is true because the fastest we could get my friends '97 Z28 was 120, and I have gotten my '94 up to 135. I think they said that the Lt1 tops out at 160. Has anyone done that, just to be sure its true?
Old 04-07-2004, 08:39 PM
FormulaLT1's Avatar
Fight the powwa!!!
I have gone over 120 in my car but I have my car programmed so I don't know but you could can find out pretty easy with a call to a F-body tuner
Old 04-07-2004, 11:09 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
well aslong as u have Z rated tires from the factory then ur car should not have a govenor.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
False Advertising - New photos of the Black F1 GT Peloton25 F1 5 05-19-2010 01:09 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
97 ford escort lx headlights stopped working christopher1169 Escort 4 02-14-2009 09:48 AM
