Old 10-20-2005, 08:22 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: Side Mirror Vibration
rlith, was it pre-wired, or did you wire 'em?
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 10-20-2005, 08:35 AM
SComp23 SComp23 is offline
The way that they connect to the wiring from the truck is different, if I recall you have to make your own connections.
Old 10-20-2005, 08:44 AM
mike1224's Avatar
hmmm, i know that they are useful to have, but how often do you guys use them?
2002 Chevy S-10 ZR2
Old 10-20-2005, 08:55 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I just used the pigtails off the door harness and the pig tails off my old mirrors to make a translation harness. Then wired the heater element to my rear defrost circuit.
Old 10-20-2005, 09:01 AM
mike1224's Avatar
ahhh problem there, i have no rear defrost (pickup)
2002 Chevy S-10 ZR2
Old 10-20-2005, 10:03 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
my mirrors seem to flap in the breeze because one hole on each side is stipped. any ideas how to fix?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-20-2005, 10:17 AM
rlith's Avatar
Do you mean the mirror stud on each side? The only thing I could think of for that would be to re-cut it with a die and use a new nut... Or replace the mirrors.
Old 10-20-2005, 11:17 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
If you can find it:
I had the same problem with a wiggly mirror, then - someone slammed a car door into it and did me the favor of leaving it there on the side of the truck, dangling by a wire. *sheesh*
I found a special epoxy used for metal-plastic bonding, that once cured will withstand about 35,000 PSI of pressure. This is NOXIOUS smelling stuff, so do it outdoors or in a ventilated area. Glue the stripped studs back into the mirror with this stuff, and let it set for an hour. Once cured for an hour, it's ready to be handled. Bolt it back up. My mirror is wiggle-less and the bond is plenty strong. I now fold my mirrors back daily to keep the idiot neighbors and the freaks parking mud-tired, jacked up monster trucks into compact car zones on campus from whacking my mirrors off. So far, it's held up for more than a year of me flipping it in and back out, daily.
Old 10-20-2005, 11:58 AM
Buy the 98.5+ mirrors, that is the only fix to this problem. The older mirrors tend to crack on the bottom of the mirror by the swivel. That, in addition to the fact that they are made with very cheap and not sturdy plastic, is causing the vibration. Replace them with the bulky 98.5+ mirrors.
Old 10-20-2005, 04:35 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Re: Side Mirror Vibration
Originally Posted by wolfox
If you can find it:
i'd like to eventually replace them because the front part of the base is gone on the drivers side. it looks like someone in the past tried to glue them down. thats why i'm not gonna glue them down at this point
Low 11 sec sleeper
My Cardomain
Old 10-21-2005, 08:44 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Re: Re: Re: Re: Side Mirror Vibration
Originally Posted by rlith
Yep... Have a set on mine with the defrosters on them.
but then again, the triangle piece that it bolts to the body with looks the same.. can you convert the flimsy style mirrors to the double swivel kind?
i wish i had defrosters, i just wipe mine off with the sweatshirt or something lol.
Old 10-22-2005, 06:44 AM
rlith's Avatar
Re: Re: Re: Re: Re: Side Mirror Vibration
Nope... The triangle mount is the same shape but you can't swap them with the other mirrors..
Old 10-22-2005, 10:31 AM
Re: Re: Re: Re: Re: Re: Side Mirror Vibration
Are you saying you can not swap out the mirrors from a 1995 96 97 with the mirrors from a 99,2000,01 etc?
How to install mirror into LH side mirror assembly? Bill Deville Grand Marquis 2 10-12-2010 10:19 PM
1999 Sebring Conv. right side mirror doesnt move Foxypsycho Sebring | Sebring Coupe | Convertible 0 04-24-2010 05:00 PM
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 07:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
Vibrating Drivers Side Mirror Spinman Aurora 0 05-03-2004 06:50 PM
