Old 03-22-2004, 12:51 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: Re: are stock jdm engines faster than usdm stock engines?
Originally Posted by mrlucci4051
alright so eckoman, for a daily driven vehicle would turbo be the safest bet?
I'd go with a turbo (make sure to use an intercooler) running low boost, say 8psi or so. That should give you an extra 80hp or so (give or take), which is more than a supercharger will give you. It'll put you well over 200HP. That should be enough extra power on a daily driver, and the turbo will be responsive: you won't have much lag at those boost levels. Just keep the motor tuned right.
Also, remember, whether it's turbo'd, supercharger'd or stock, the harder you drive it, the quicker it will die. Running a turbo @8psi on the motor will be safe. Use a Hondata if you can afford it, especially if the kit comes with a fuel pressure regulator. They arn't that great, Most supercharger's and "turbo kits" come with one as the fuel managment, so you'll want to think about that. A Hondata is bascially a Honda ecu that has been reprogramed, they've cracked the factory codes so they can re-progam it for whatever your needs are. It basically funactions like a stand-alone ecu. Keep the motor tuned and don't abuse it, and you'll be okay.
A low boost turbo is the route I would go on a Daily Driver.
Old 03-22-2004, 09:07 PM
mrlucci4051 mrlucci4051 is offline
ahh that's a big help. i think i'm gonna trust you on that one. Now THE big thing should i get like a shell from the u.s. or maybe try and get a shell from japan and have a right hand drive? And how much do you think i'm gonna be spending 'cause i'm gonna do all this stuff within the next month
Old 03-23-2004, 11:46 PM
Honda God
I am guessing you are in the US, right? If not, where are you at? If you are in the US,it will be much easier and much cheaper to get a car here and dump the motor into that.
Old 03-24-2004, 04:23 PM
yeah in live in good old Gainesville Florida!
Old 03-28-2004, 04:48 PM
Honda God
Yea, that being the case, just get a US car and build that.
Is a c4 corvette engine faster than a 1995 z28 camaro? portland5 Engine and Transmission 16 06-18-2007 04:57 PM
Are Naturally Aspirated cars faster than Turboed cars? NewyorkKopter Engineering/ Technical 14 09-10-2005 10:09 PM
Did you know there are at least two other cars that are faster than McLaren F1? iLikeMyDamnPrimera F1 86 07-14-2004 03:45 PM
successful gsr turbo?or stock faster than ls vtec integraluva Integra 3 12-08-2003 05:30 PM
What makes more HP in a JDM engine rather than a USDM engine? asnrefugee Engineering/ Technical 8 06-20-2002 01:32 PM
