Old 06-08-2002, 01:32 PM
asnrefugee asnrefugee is offline
Send a message via AIM to asnrefugee
What makes more HP in a JDM engine rather than a USDM engine?
Is it the compression that makes more HP?
or is it something else?
Old 06-08-2002, 04:08 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
most of the time it's the compression...
Old 06-08-2002, 08:10 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The Japanes have access to higher octane fuel, and so normally all the engines sold in Japan have a higher CR than the rest of the world.
This is done mostly to make them run cleaner, but can also give them a few more HP, since the ECU is also differnt to deal with it. (runs more agressive ignition timing etc)
However some engines like the B16a also have more aggresive cams.
Why no one knows, it either the Japanese being snobs and keeping all the best bits to them selvs, or is Honda only allowing detuned versions to be sold overseas to make it easy to meet all international emissions laws and run on all grades of fuel with out having lots of differnt engines types.
Old 06-10-2002, 07:53 PM
rendog24's Avatar
rendog24 rendog24 is offline
would you be able to run a jdm engine with the same octane we have compared to the higher octane they design it for. would it fuck up the engine?
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
Old 06-11-2002, 02:46 AM
Moppie's Avatar
Master Connector
It certianly won't fuck up the engine, but some of them will not run at thier full potential.
An engine like an old ZC from a 4g Civic will run perfectly, but a newer H22 might be down 10 or more hp.
Old 06-11-2002, 02:59 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I run my SiR on 98 Octane Optimax. I tried 96 premium and it ran like shit - well, it wasn't too bad, but the 98 made it run a hell of a lot better.
ZCs should be fine on 96 octane though - that's what was recommended for our ZC CRXs which ran the same ECU/Engine spec as the JDM ones.
Honda Australia recommends 96 octane but suggests 98 is better on all the performance VTEC engines.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 06-16-2002, 10:44 PM
Gmac Gmac is offline
Send a message via AIM to Gmac
Usually it's a combination of cams, ecu, c/r and/or fuel used.
In NZ, we also get 98 Octane at the pump in most places, and I kjnow my JDM B16a2 runs much better on the higher Octane. But with a bit of tuning you can prolly make up for it.
Honda would release slightly differnt vcersions of motors in different countries so they are 'tuned' to suit the fuels and conditions available in each particular country.
PUTOUT
Old 06-17-2002, 06:47 PM
CRX586's Avatar
CRX586 CRX586 is offline
Damn, all I can get is 91.
What about octane boosters/additives? Do these really help, are they worth the $$?
Old 06-20-2002, 01:32 PM
SimplyHONDA SimplyHONDA is offline
I can only get 91 oct.
yeah, so what ups with oct. boosters?
