Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 11-10-2004, 10:40 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
a honda doesn't redline at 7000 rpms though the tach says it does Im pretty sure the 93 honda civic redlines around 5900
No buddy...mine redlines at 7200 and i can run it there perfectly fine. and thats with stock internals
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-11-2004, 01:37 PM
PhlatulentPhreddy's Avatar
PhlatulentPhreddy PhlatulentPhreddy is offline
Re: Redline And Shift Points
I believe any accent after 2000 has a rev limiter and probably the models before. Web Tech on the HyundaiUSA site will tell you for sure; I guess it used to be known as a governor to prevent the engine from redlining. I've never had it kick in. It's supposed to slow down the engine when it reaches a certain RPM. I think redline on accent is 6,000 but have no tach so I defer to someone else's expertise there. I've taken 3rd up to 60 but wouldn't recommend doing 80 in 3rd often. Then again I'm not speed racer i.e., I bought a car with a 1.5 Litre v4. Nough said.
Old 01-07-2005, 09:25 PM
XchiboiX XchiboiX is offline
Send a message via AIM to XchiboiX
wtf, on an accent, sh!t thats pretty quick, but did it accelerate fast, or did it take u a long time to get up there?
Old 01-11-2005, 02:05 PM
Shift Points
It ain't a Ferrari and it isn't like I could put a C-note on the dash board and run the gears and the g force is going to keep you from snatching it but the car can get going in a hurry if it has to. The stick is the trick. 1st doesn't offer much but 2nd and 3rd will get you going quickly. I don't drive like this often but sometimes getting onto 95 or an entry ramp I need something to happen when I hit the gas. I find 3rd to be the most productive gear. FWIW Peace
