Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-29-2002, 01:34 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Originally posted by JimmyOOOOO
Spoken in true rice fashion...
Intake and Exhaust on a WRX are NOT what you want to do first as far as power goes. You want to get a ball & spring MBC from www.dawesdevices.com and set it to 15 psi @ 4000 rpm in 4th gear. Then do the resonator mod. Then get an upipe and lightened underdrive pulley from www.vishnuperformance.com
Second, new tires are a MUST. The RE92s are a hazard.
Third, Do the "Grounding Mod" described HERE . This will make a very noticable difference in the way your car applies power when you hit the gas.
Things to stay away from:
1. Blowoff valve
2. K&N Filter
3. Catback only (full turboback is a good mod)
check out www.-club.com regularly for lots of great WRX info
Hey meathead - there is NO rice in what I said. No 'Add some stickers' or 'Get a catback system'. Besides which, a catback system will give you a performance gain (although I am against them) and my package would give much better power for dollar value. Blowoff valves are wank for the sound and lastly performance filters in the factory airbox have given a 4kW gain (dyno) and more when coupled with other breathing mods like exhaust, IC etc.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
  #17
Old 03-29-2002, 03:29 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Lets not get into a discussion on rice. ozriceboy's suggestions were good.
And K&N Filters and full kits are some of the best in the business. A cat back exhuast helps a lot, but you can't neglect the cat itself and all that comes before it.
But all these suggestions are good, I just wish I had a WRX
You can live in a car, but you can't drive a house!!
MSN: [email protected]
  #18
Old 03-30-2002, 03:29 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Thankk-you. And agreed bout the WRX thing. We have an Impreza GX, but not a patch on the real ting.
  #19
Old 03-31-2002, 02:03 PM
Tsui Tsui is offline
Send a message via ICQ to Tsui Send a message via AIM to Tsui Send a message via MSN to Tsui
So you guys are saying blow-off valves aren't good?
I thought that the blow-off valves allows boost pressure to be relieved from the intercooler hoses when shifting? Hence the turbo stays spooled?
Someone clear this up?
What signature?
  #20
Old 03-31-2002, 05:08 PM
auswrx auswrx is offline
Send a message via ICQ to auswrx
Reduces turbo lag somewhat.
Everything we have will be destroyed by time or death, the things that cannot be destroyed are the most important.
  #21
Old 03-31-2002, 06:41 PM
yes, unless im wrong that is.
What signature?
  #22
Old 04-01-2002, 03:21 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Yeah, but the WRX comes standard with a BOV that vents internally.
  #23
Old 05-04-2002, 10:17 PM
Chris's Avatar
Oldie
Am I incorrect in saying the BOV is to relieve the excess pressure created in the intake after the turbo. When upshifting, you release the gas (normally), so less air is being admitted to the cylinder as the revs drop (revs stay down after shift also). But the turbo is still going really fast, pumping a lot of air in. So the air going into the cylinders is now really pressurized. This could cause all kinds of problems, especially the cool breaking-expensive-parts kind.
  #24
Old 05-12-2002, 02:26 AM
Impreza555 Impreza555 is offline
Send a message via AIM to Impreza555 Send a message via Yahoo to Impreza555
up pipe, down pipe, Exhaust. Very first mod as far as power goes. Next would be a Boost controller. Not a good idea to up the boost with the stock piping, (if you have the US version) there is a catalytic converter on the up pipe, when the boost is raised its been known to break and send the pieces of the cat into the motor. Bet you can figure out what happens next.
Subaru, the beauty of (turbo) All-Wheel
Drive
You see a dirt road, rocks, overhanging
trees and creeks. I see the drive of a
lifetime..............Rally Up
  #25
Old 05-12-2002, 03:48 AM
GT30Girl GT30Girl is offline
Leave the factory recirculating BOV as it is. If you've never had an aftermarket BOV before, you may be tempted to get one for 'wank' factor but you'll notice the quality of your driving when in the twisties goes down hill.
When you're giving it a bit in the hills/ low speed twisties there are many times when you're holding the throttle at a certain revs in 2nd gear especially, when going through mutiple low gear corners. If you have a BOV venting to the atmosphere it starts venting off boost while you're trying to maintain a certain rpm which makes the car go into a kind or mild 'bunny hop'.
When you recirculate it, it fells like a new car again!
Your first mods on this car should be the same on any other - exhaust and intake.
- And don't forget a boost gauge to compliment you're boost controller when/ if you fit one -
  #26
Old 05-13-2002, 09:46 AM
Front mount intercooler would be one of the first couple of mods also. MRT makes really good ones.
Drive
  #27
Old 05-14-2002, 04:26 AM
The WRX top mount intercooler is actually quite good compared to other top mounts. I'd stick with it unless your upping the boost a lot or changing to a bigger turbo - not that a front mount wouldn't be better.
  #28
Old 05-16-2002, 11:17 AM
Cmotif's Avatar
Cmotif Cmotif is offline
Send a message via AIM to Cmotif
I think Hiro, Trunkmonkey and Chris are right!
Tires first. Subaru does not put the best tires on your car. Maybe Ferrari puts the absolute best tires on their cars, so when you drive off the lot, you have the best you can get. But all the other companies are trying to cut corners.
The tires are the only part of the car that touches the road, so it is the biggest area of improvement. Once you have that sorted, then you can know what you need to do next for your specific needs.
Cmotif <><
Into RC Car racing? Check out www.rctech.net The Number One RC Racing Community on the Net!
  #29
Old 05-16-2002, 01:35 PM
Super Spec V Super Spec V is offline
RE
VERY VERY GOOD POINT.
Too many people write off their calls, because they have lots of power and carppy tires to put it to the ground.
A Game of chess is like a sword fight. You must think first before you move!
  #30
Old 06-11-2003, 10:33 PM
dRiFt_kInG dRiFt_kInG is offline
Send a message via AIM to dRiFt_kInG
u should jus get rims mang
basic first mods for NEWBIE fishhouse Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 15 08-10-2006 05:01 AM
what would be a good first mod for my 1990 celica st ThaKidz2Nice Celica 13 05-07-2004 12:29 PM
First mods for 97 GTP MoshimoGTP Grand Prix 1 03-31-2004 12:12 PM
what should i do for my next mod?? redmaxpa007 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 05-22-2002 08:57 PM
Closed Thread
