Old 03-31-2004, 11:18 AM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
First mods for 97 GTP
Im thiking to do the following mods:
-3.25, 3.30 or 3.4 pulley <-----???? What size are correct???
-TB Spacer
-Tstat 180 drilled by ZZP
-TR6 Plugs (NGK)
-Tranny Cooler
-Fenderwell Intake
-Free flow exhaust
Comments, Suggestions?
Thanx
MoshimoGTP
Old 03-31-2004, 01:12 PM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Re: First mods for 97 GTP
You should start with the 3.4 Pulley and get a scan tool to monitor your car for KR, o2s, misfires, and a few other parameters. You should also add a Cold Air Intake, a 180 thermostat, and remove the U-bend in the exhaust at the same time to prevent potential KR. If you are planning on modding further you should get an interchangable pulley system so swapping pulleys isn't as dangerous and time consuming.
For more information on using smaller pulleys like 3.25 or 3.0 check out this site for some performance recipes:
performance recipes
