Old 06-11-2004, 11:48 PM
oncedesired oncedesired is offline
Send a message via Yahoo to oncedesired
Re: '97 GP - Key stuck in ignition ?
Sorry this is late, but I just saw these posts. I had the same problem with the key not wanting to come out of the ignitition. What is happening is the button you depress to shift is getting stuck in the shifter when you put it in park so the car doesn't realize you're in parking gear. Just pull the button out by pulling on it slightly & the key will come right out.
Old 01-27-2005, 10:11 PM
2000GPGTBlue2dr 2000GPGTBlue2dr is offline
Check the BTSI fuse!!!!
I had the same problem with my 2000 GT. Guess what??? Here's what is wrong. I replaced the shifter ($250) thinking it was the solenoid attached to it, and the P R N D 3 2 1 lights on the dash still kept flickering, and the key would not release out of the ignition when I put the car in park... So despite what the so-called pros in these forums say it's not the shifter solenoid.
There's a 10 amp fuse for the BTSI (see your owner's manual) which is the Automatic Transaxle Shifter Module. Believe it or not sometimes the fuse doesn't make contact with the fuse housing causing an intermitent connection that causes the BTSI that controls or signals the solenoid near the ignition that the car is in park thus releasing the lock to work "off and on."
So here's what you do.... Take that fuse out clean it off, and then actually bend the 2 pieces of metal sticking out of the fuse in opposite directions so that when you put the fuse back in, it ensures a stronger connection to the pieces of metal inside the fuse housing. I did this and the lights no longer flicker, and everytime I have the car in park I can shift to other gears, and I can release the key out of the ignition.
It's funny sometimes you can't always listen to ASE certified techs in these forums 'cause they steer you into buying extra parts you don't need just like the dealers do.
Old 01-28-2005, 08:48 AM
winn_27 winn_27 is offline
how i fixed it
i yanked it out with a tool and it started with out the key. ( was gonna replace it anyways) . after i yanked it out i just replaced it and then a few months later i wrecked the car...damn foreign cars. and if your shifter get stuck then when you shift it kinda pull up on it and then click it...check if there was anything spilt too because someone did that to my car when they barrowed it.
2002 Blazer Stalls, Key Stuck, Won't start MarkSpeed6 Problem Diagnosis 5 08-30-2010 02:14 PM
Key stuck in ignition--1999 6.8L v10 Too Many Old Cars Club Wagon 1 08-28-2010 07:56 PM
Key stuck ignition switch Crow Grand Prix 56 07-17-2006 09:58 AM
'97 key stuck in ignition bisbee Grand AM 2 09-29-2003 06:39 PM
Key stuck ignition temp. fix jet black Grand Prix 0 08-11-2003 07:39 PM
