Old 01-27-2004, 09:37 PM
CADguy's Avatar
CADguy CADguy is offline
Re: Tips & Techniques: Building the Tamiya Ferrari Testarossa!!!!!!!
Thanks for that tip! Those 4 ridges are so small.
But they important to detailing of the Testarossa engine.
Can't wait to try it.
Matt
Old 01-27-2004, 09:42 PM
pflau's Avatar
pflau pflau is offline
now on to the show piece.. the airbox. this is the blow-by-blow..
I first spray the parts with aluminum metalizer.. after that I spray a VERY LIGHT coat of model master clear gloss enamel - you dont want the thing to look really glossy. I used the enamel from a spray can, sprayed it into an airbrush, and "dry airbrushed" it on the parts. I like spray can paint if I will always spray it because the paint is always "fresh"
now I let the parts dry for a day.. and came back to apply the red. now the way I applied the red color is VERY important.. I used tamiya flat red. because tamiya paint can be easily removed with fantastik household cleaner. I really really thin the paint down.. probably 1 part paint to 3 parts water. and I "pool" the paint onto the center area. the key is that
if the paint doesnt spread out quickly from capillary action it is not wet enough
WHY you ask.. the key here is that you want to get as much paint as you can between the lines.. but as little as you can on the lines. and you would need to apply at least three coats when the paint is that thinned out. but once you apply the first coat and other coat will be easy because you just touch the paint brush on the paint and the capillary action would drew the paint over the entire area.
you can sorta see what's going on from this picture.. note that
the paint is SHINY even though it is supposed to be flat.. that tells you how watery the paint is.
another reason why the paint has to be watery is that this way the paint would dry flat and even between the lines.. if the paint doesn't dry flat.. it would look really ugly from an angle.
Current project:
Ferrari 360 Spider Testarossa, F40
Porsche 959
Fujimi Lamborghini Countach LP500S Enthusiast Model (no end to that!)
Old 01-27-2004, 09:59 PM
pflau's Avatar
now after the paint dried for a couple hours.. here's where the fun began. now I needed to remove the paints on the lines and the ferrari and testarossa scripts. dont wait too long because the paint would be too dry. so couple hours is good.
I use a piece of paper wet with fantastik and gently rub back and forth along the top.. along the direction of the ridges.. be patient and the color would gradually come off.. but be careful not to get the color on other areas because red can stain anything and is hard to remove completely
now here's the reason why I sprayed on a light coat of clear gloss earlier.. if I didnt the alumium metalizer would come off along with the paint. but because enamel is hard and is immune to fantastik.. it protects the alumium underneath.
now for the scripts.. they are recessed and the paper would not get to them.. for them I used that micro brush introduced in my 360 spider buildup.. I do the same thing.. wet the brush with fantastik and rub off the paint from the scripts
when you wet the paper and the brush.. do not use so much that it runs all over and end up removing paint between the ridges that you dont wanna remove.
after Im done.. I wait for a day and seal the whole thing with a thin coat of metalizer sealer.. and the result speaks for itself..
Current project:
Porsche 959
Old 01-27-2004, 10:11 PM
pflau's Avatar
now allow me introduce one of my most valuable tools.. my magnifying glass..
I got it from www.micromark.com but I only use the glass and I never use the arms.
I paint many things under this glass.. with a small clamp on desk lamp and a couple small brushes. that's how I did the alternator/starter/belts at the end of the engine. I sprayed the belts flat black and hand painted the alternator and the starter using aluminum metalizer. the reason is that hand painting flat black might cause the black paint to build up too much and the belts would end up looking bad.. but metalizer does not build up and is much easier to apply around the belts.
this is the finished engine..
Current project:
Porsche 959
Old 01-27-2004, 10:20 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
the attention to detail...awesome. you are a detail god!
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 02-16-2004, 07:30 PM
pflau's Avatar
hi again. been busy so I haven't got around to building too much. just one quick thing I did that seems interesting to share.
I've been looking around to get some Gunze Sangyo Masking Sol Neo or Humbrol Maskol but couldn't find it anywhere. the reason I need that is for the wheels. see the wheels are not all chrome or aluminum.. its actually aluminum with a very bright chrome center cap, as you can clearly see in this photo:
now how do I recreate that effect?? the instruction says to paint the center cap X-11 chrome silver.. but the problem with chrome silver is that 1) its never gonna be as shiny as chrome and 2) to get a shiny surface the paint would need to build up and the center cap would look out of scale.
so the best way to do it is not to paint the center cap.. which is already chrome plated, but to paint the rest of the wheel aluminum.. to create a contrasting effect.
to do such painting I need to mask out the center cap and spray the wheel aluminum.
since it's impossible to mask out the cap using tape.. I need a masking agent. I heard some good thing about Humbrol maskol and Gunze Masking Sol Neo but I couldnt find any in my local hobby shops.. so I gave this a try:
http://www.walthers.com/exec/productinfo/904-106
it turned out to be pretty good.. just dont expect to be able to cut it with a knife.. once the paint is on and dry.. that's it.. you can not trim it.. you can only remove it... this is not bare metal foil.
so here I go masking out the center cap.. note that I use a lot of paint and make sure the paint covers the groove around the cap so the cap would appear 3D.. otherwise the cap would appear like a thin piece of paper because the edge is painted over.
also.. using a lot of paint prevents the paint from drying too soon while you're still painting.. absolutely a no-no cus you would end up pushing the mask around or even lifting it.
if you screw up.. STOP!!!. let the paint dry and remove the mask. if you dry to wash it off while its still wet you would make a big mess that you cannot get out of.
do not let the mask dry overnight or you would risk it sticking too well to the chrome and you might lift the chrome when you remove the mask.
after the mask dry (when its turned from white to translucent) I spray on some TS-30 silver leaf.. I use that instead of say aluminum metalizer because metalizer dries way too fast so when I remove the mask I leave an edge that looks "ripped". the tamiya silver leaf is a little brighter than I want but it does have a smooth texture that doesn't look out of scale and looks matt next to the chrome.
after I spray silver leaf.. I let the wheel stand for about 4-5 minutes.. and I remove the mask with a pair of sharp tweezers.
that's when using a lot of masking paint became vital because the thicker the mask the easier it is the tweezers can grab on to it. a thin mask and you risk the tweezers scratching the chrome and you would have a hard time removing the mask. you can always use a piece of masking tape to remove the mask but the tape might inadvertently remove bits of chrome.. and you're screwed when it does.
after Im through all that thats how they look:
not bad huh????
one more thing.. the masking paint is a real pain to get off the brush.. use paint thinner followed by alcohol..
Current project:
Porsche 959
Old 02-16-2004, 10:27 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Nice!
Just add some valve stems and you'll be set.
SCCA 7, The lost Z
Old 02-16-2004, 11:30 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
If that ain't detail I dont know what is!!!!!
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 02-16-2004, 11:40 PM
JBarry's Avatar
JBarry JBarry is offline
Send a message via AIM to JBarry Send a message via Yahoo to JBarry
WOW! I have never been so impressed and lucky at the same time. Last night I won this kit on ebay for 3 bucks. I have bookmarked this thread and will print it out if I have to. I need a few more builds under my belt before I would even attempt this car. Like every car you build, it's going to be perfect and I want mine to shine too! Thanks a million for all the time and effort you put into teaching me and the other guys.
J. Barry
Old 02-17-2004, 09:42 AM
pflau's Avatar
wow you got it from ebay for 3 buck?!?!?!?!? I got mine from ebay for $13 total and I bought it because I thought I was missing a couple parts but I wasn't.. so I decided to rebuild it since I had the kit anyway and I wasnt happy with my last build..
Current project:
Porsche 959
Old 02-17-2004, 10:03 AM
CADguy's Avatar
Your wheels look great.
I think the wheels Ferrari chose for this car are kind of plain and boring. I've seen many TR's with different wheels while doing research on this car. I won't be using those when I finally complete my build too.
Matt
Old 02-17-2004, 10:14 AM
pflau's Avatar
yeah but this is meant to be a miami vice testarossa so I want to stick with the factory spec..
except for the body color.. Ive decided to use dupli-color toyota super white II because that's the color of my real car..
Current project:
Porsche 959
Old 02-17-2004, 10:20 AM
CADguy's Avatar
Mine's gonna be Cranberry Red Metallic. I found a pic of a TR in this color and loved it. I'm gonna spray it tonight. Can't wait to see how yours turns out.
The BMF tip worked great too! Thanks!
Matt
Old 02-17-2004, 10:33 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
This is exactly the way I painted the wheels on my Testarossa- but if you'd asked before, I probably could have saved you a bit of effort in scrounging for masking solution!
A very similar masking solution can be made by mixing plain white glue with just a touch of dishwashing detergent, and then adding a drop or two of food coloring. Apply, let dry, paint. Again, don't expect to cut it with a knife, but when it's wet, it's easy to manipulate- if you slop a bit where you don't want it, wipe it away with the tip of a toothpick. The coloring makes it easy to see when dry.
Your painted rims look spot on. Ferrari wheels are nearly always brushed aluminum (or magnesium alloy!)- so all chrome wheels tend to look goofy and toylike. But the chromed center makes for a lovely contrast. A light wash of black on the wheel nut makes it stand out a bit more (and not look like a one piece casting on the wheel center), and helps emphasise the gap between the chrome/brushed aluminum parts.
Lookin good!
Old 02-17-2004, 01:56 PM
86_SR5's Avatar
looks great!
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
