Old 01-25-2004, 01:28 PM
awwynn awwynn is offline
Re: after market stereo problem: no power
LOL. great. maybe i should look into trading it in.
Old 01-25-2004, 02:53 PM
ok, got the tester, tested from grnd to red power wire and its live. tested from grnd to mem wire, no good. ??? also, accidentally connected mem and pwr wires and door chime went off (doors were closed).
Old 01-25-2004, 04:13 PM
algoesfast algoesfast is offline
Send a message via MSN to algoesfast
did you turn the key on and check for voltage on mem? The power wire was probably back feeding the door chimes.
Old 01-25-2004, 04:15 PM
Check from ground on harness to power wire. Unless thats the way you already tested. You may have power but lost the ground.
Old 01-25-2004, 04:45 PM
i figure its the radio now, cause when the car is on, theres power from ground to the red power wire, but nothing from groungd to yellow memory wire. still nothing on the radio tho. should i just chuck this deck and buy a new one?
Old 01-26-2004, 04:32 PM
What about the door chimes? Do they work with the deck out? Because if I remember correctly you said the chimes and deck stopped working at the same time. What ever happened may have killed your deck. But it could happen again to a new one. Worth thinking about. I know nothings ever easy.
Old 01-27-2004, 03:11 PM
yeah, thats why I'm hesitant on buying a new one. im ot even sure if this one is bad yet. and the door chimes dont work. i still can't get any juice to the mem wire. ARGH.
Old 01-27-2004, 05:42 PM
honeybabes honeybabes is offline
Re: Re: after market stereo problem: no power
if you did this check and there is a power on "red wire to ground" and no power on "yellow wire to ground", the problem should be on the car wiring. You can check if your deck is not working by:
- ground the deck
- hook the red wire straight to battery or anywhere that has 12V constant
- if the deck didn't power up, connect the yellow wire to 12V instead of the red
- if there is still no power connect both red and yellow at the same time to 12V
- if it powers up, it is still good
- if not chuck em'
hope this helps before you garbage that deck.
Old 01-29-2004, 08:47 AM
thanks honeybabes, good thing i didnt toss my deck. works fine. i figured out what the problem is i think. the memory wire isnt getting any power, so i think it shorted out somewhere upstream. i tried putting power to the mem by connecting main power and mem, worked for a minute, then blew a fuse in my box. i think the short might be with the horn's wiring, or the cig lighter. i looked in the haynes maual, and the mem wire also connects to the "multi function alarm module" so i think thats why my door chime isnt working. its on the same circuit.
Old 02-06-2004, 11:49 AM
cavsport2000 cavsport2000 is offline
when you hooked up your radio did you use the factory ground? if you did try grounding it to a bolt or something that is near the front of the car where it can be hidden
98 Trooper rear window FM Atenna connection with after market stereo devind Trooper | SLX | Bighorn | Wizard 5 10-09-2005 06:39 PM
After market stereo installation Wubs Montana/Montana SV6 2 08-25-2005 11:35 AM
Adding battery back-up to after-market stereo? Faze3 Car Audio 2 05-14-2005 08:15 AM
After Market Stereo for J30??? kyuj30 Cedric | M45 | J30 | Gloria 4 12-15-2004 08:43 PM
After market Stereo and Seat memory tinijeep Grand Cherokee | Grand Cherokee SRT8 2 12-17-2003 06:37 PM
