Old 01-05-2004, 02:30 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
ratdat
thats a nice clean booth, one potential problem that yuo might consider however. ANyone who I have talke to about spray booths has always stressed using a sealed fan or one specifically made for exhausting vapors. The heater fan from the car that you have used has the potential to spark and cause an explosion. A computer fan is a good alternative as these are completely sealed.
Have you used it yet???? Just wondering how well it worked????
I will post pics of mine when its complete.
D
Old 01-05-2004, 04:45 PM
ratdat's Avatar
ratdat ratdat is offline
Re: How To Make a Paintbooth?
That was actually one of the considerations when I chose the heater fan and the main reason for using it. The motor is mounted outside of the plastic casing away from the fan. It's mounted like this on a car to keep it away from any moisture present in the air. The motor shaft passes through a seal into the casing so the motor is definately sealed well away from any potential vapor hazard.
I don't know if all car heaters are designed this way but all the Nissan ones I have seen are. The fan is also extremely efficient and reasonably quiet.
Eddie
RATDAT.COM
Current projects...
Finished...
Old 01-05-2004, 04:51 PM
dag65's Avatar
Good thinking, sounds like your fan is okay. I just wanted to throw that out there for thought, I' d hate to hear about an AFr who blew himself up using a bathroom fan or something.
D
Old 01-12-2004, 06:23 AM
villajames villajames is offline
if you need a low powerd fan, go to the junk yard and get a fan out of a junk car(heater fan). it runs on 12 volts and blows just the right amount of air. if you go to a cheap yard you can spend about $10 for a blower, and about 25 dollers on wood.
Help with make/model identification saltyone General Discussion 1 04-27-2010 08:51 AM
Critique my DIY PaintBooth DocTegra Cars in General 1 03-24-2008 10:52 AM
how do you make t.v's for cars what kind of material do you use and making amps eddie29 Diecast Car Modeling 2 05-30-2004 09:51 AM
I was wondering if anyone could make a detailed instructions on how to make a turbo? timjecks Car Modeling 8 05-28-2004 06:05 AM
How do you make a direct pipe from your exhaust to your engine to make it louder? Lingerie_Ripper Prelude 14 02-03-2002 10:20 PM
