Old 12-23-2003, 06:31 PM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
Re: Best performance for the $
go with K&N for the intake, they dino more then the v2. also the v2 application only makes around 10 - 15 additional hp while a k&n system can makeup to 25. it also cost ALOT LESS
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take"
Old 12-23-2003, 09:10 PM
goalieman24's Avatar
goalieman24 goalieman24 is offline
Send a message via AIM to goalieman24
have you seen these dyno charts for the eclipse showing the 25hp gain?
soon to be stage 2
Old 12-25-2003, 10:18 AM
Afrokid's Avatar
http://www.knfilters.com
Old 12-25-2003, 08:03 PM
and where might the dyno chart be?
soon to be stage 2
Old 12-26-2003, 01:30 AM
amdsoldier amdsoldier is offline
Afrokid,
Seriously how can you believe that? There is no way that an filter can add 25HP. Thats just stupid talk.
EclipseRST,
Thanks for replying, wow I didn't realize though that those components can add up that much (ie cost).
What upgrades would you recommend in order would you say after the ones I listed?
I was thinking the next thing to do would be getting a short shifter, pulley (wonder if this really works, about 8lb difference I believe...) and some cam gears. Other than that I can't think of anything pretty simple not too expensive to upgrade at the moment.
Old 12-26-2003, 04:53 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Originally Posted by amdsoldier
EclipseRST,
yea i would definatly do a CAI of some sort, it really doesnt matter what kind, underdrive pullies do add some power but not much - ok when adding performance upgrades you cant expect much from one upgrade like the underdrive pullies...exspecially when modding a 420a, you will need to add a few upgrades before you will actually feel a difference in your cars power, i would suggest getting a new coil pack (the block that your plug wires go into on top of the valve cover - just incase you didnt know what it was) get some new wires and plugs... all that should be about a $100-125 dollars, get the underdrive pullies - somewhere around $150 where how much mine were... an aluminum flywheel would help add power - you can find one for about $200... for the CAI, depending on if you make your own or buy a name brand one - from about $30 for home made to $180-200 for name brand. now with all that you can be pretty close to seeing about 30hp gain... now it doesnt see much for the price but if you want an easier way for a little more, make the home made CAI, about $30 and you could get a walbro 190lph fuel pump for about $75 and get the stock 450cc injectors from a 4g63 for around $50-75, that will upgrade your fuel system enough to get a nitrous kit, i would suggest a 50-75 shot zex wet kit... brand new for about $450-500 off ebay - thats where i got most of the prices from! and with the upgraded fuel system and the nitrous you could see up to 75hp, now thats double the hp for a little more money if not the same price...now if you do all of the above for a little over a grand, you could be seeing about 100hp added to your car, now remember (and this is for all of you that are goin to say yea right 100hp - BULLSHIT!) thats at the crank, so you will probably see about 65-70whp!
now if you would have gotten a GST or GSX, for a little over a grand you could running low 13s! remember that!!!
Old 02-24-2005, 11:43 PM
99JLEclipse 99JLEclipse is offline
Send a message via AIM to 99JLEclipse
With the 420 motor in the Eclipse. I suggest first doing your exhaust work. Then some Fuel Work like this
Catback Exhaust, High Flow Cat, Header, Intake Manifold, Intake, Throttle Body, Fuel Rail, Fuel Regulator, Fuel Pump, Injectors. With this stuff you will be decently quick. Another thing that will help you out alot is the Venmon 400 Chip. Also with the above stuff get spark plugs and wires. This is just what I think I am not an expert.
Old 02-25-2005, 12:58 AM
EclipseRST's Avatar
Banned
This is over 2 years old... Look at the date next time before you post. Make sure it isnt older than a month or so unless you have a question that was not answered and pertains to something covered in this thread.
Welcome... Go read over the rules and put your car in your sig.
Old 02-28-2005, 05:42 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
short throw would be frist on my list
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
Best performance for the least money Vtec913 Performance 5 06-01-2005 01:14 PM
best performance for under 500$ 93tbird Thunderbird 25 02-02-2004 12:04 AM
The Best Job For The Best Photochoppers corvettezman Graphic Manipulation 4 03-29-2003 02:24 AM
Best performance for under $1K guyndaccord Accord/TSX/Accord Hybrid 7 03-06-2003 01:13 PM
