Old 12-24-2003, 02:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Joe covered it well. But for a 16g I would get a 15 psi spring, or 1 bar. There really is no reason to go below that. And the rule of thumb is you are safe to double the spring rating before you have problems, so its good to more boost htan you will ever run on it. For comparison, the stock actuator spring on 14b/16g etc is 10 psi roughly. If youthink you'llknock too much go witha 1 psi spring. Etc.
As another example, a car like mine that will run 25 psi without knocking on pump gas can get away with a 20 psi spring with a little room to turn it down, and enough headroom to run up to 40 psi. (LOL)
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-18-2004, 04:26 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Evo 16g Turbo Questions [once again]
just to let you know.. thoses are some expensive prices. where are you getting those?
16g Turbo Questions StreetLaw Engine, Transmission and Drivetrain 6 02-14-2007 02:39 PM
t3/t4 turbo vs. Evo III 16g turbo Afrokid Off-Topic 20 03-01-2005 09:02 PM
Upgrading questions once again ginzy TrailBlazer | Trailblazer EXT 3 02-06-2005 09:23 PM
evo 16G turbo 97turbspyder Off-Topic 5 07-07-2004 04:46 PM
16G vs. Evo III Turbo Afrokid Off-Topic 8 11-28-2003 10:04 PM
