Old 12-13-2003, 04:17 AM
V-K V-K is offline
Send a message via AIM to V-K
Re: free car runs bad but still fun to drive!
Check the old coil for cracks/stress. Also check the distributer cap as mine had cracked along the side. Just barely noticable. I purchased both for mine. It ran fine untill a couple days ago when I killed the valves doing a 110.
Old 12-13-2003, 04:18 AM
V-K V-K is offline
110: 1am, empty freeway. You get the idea.
Old 12-13-2003, 04:23 AM
pumpkinhead pumpkinhead is offline
Thanks for the help! What happened to your car? Did your timing belt break?
Old 12-13-2003, 04:25 AM
V-K V-K is offline
Let us know how it works out.
Old 12-13-2003, 04:31 AM
I prob. won't get back online till late again tonight but I will post back if that fixes it.
Old 12-13-2003, 04:01 PM
BullShifter's Avatar
Re: Re: free car runs bad but still fun to drive!
About changing the oil - Always replace the drain plug washer with each oil change or you will have a small drip.
Old 12-14-2003, 08:56 PM
IT'S FIXED!!!!!!!!! The new coil cleared up all the problems and it only cost me $70. Thanks to everyone who contributed I will definitely use alot of the info I learned here.
Old 12-14-2003, 10:49 PM
V-K V-K is offline
I lost a wrist pin on the number 3 cylinder. The car runs. Idle seems to be random, engine clicks, and smokes like a son of a bitch. I can barely get it up to 30mph now.
Old 12-14-2003, 11:04 PM
V-K V-K is offline
Also, if it doesn't have it already, adding a headlight buzzer will probably save your battery on occasion. I drained the battery 4 times from leaving the lights on. Then I installed the buzzer, no more dead battery problems after work. :P
I think it was posted in the FAQ thread... *looks* Ah yes http://www.automotiveforums.com/vbul...5&postcount=11
PROBLEM 3.1 car RUNNING BAD! triplerc Lumina 3 06-01-2006 07:02 AM
97 CV when temp goes up car runs BAD! Tony the TaxiMan Crown Victoria 1 04-16-2006 07:28 PM
engine light is on car runs fine but exhaust stinks jonnyhammer Escort 2 12-11-2004 12:55 AM
89' Delta 88: When it rains, car runs badly... 5LtrEtr Eighty Eight 2 03-14-2004 04:41 PM
