Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 10-21-2003, 08:41 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
"that just proves my point more.
you are paying even more for even less. so you get less cornering capability and less electronic control and are the same speed in a straight line"
bullshit.
you don't know anything about these 2 cars, yet you're trying to compare them?
the gt2 can far outhandle a turbo.
you haven't the foggiest on what you just said.
oh, and while you're at it, prove me wrong. . .
Old 10-21-2003, 08:53 PM
TatII TatII is offline
Re: Re: Re: North America's fastest production cars
[quote=90gs][quote=R1-riderThe corvette was using slicks, and even though it has 4 less cylinders, it has more displacement.[/QUOTE]
why would they give it slicks? i thought these were factory stock vehicles
Originally Posted by 90gs
and this just shows that ferarri is inefficient. 50% more cylinders, less displacement.
boy i thought you actually knew something about cars. but i guess not. how does it make it less efficent? you gettin more hp for per liter then that old push rod motor. the reason why the italians always use small displacement motors with a high number is cylinders is becsuae the engine runs alot smoother. compare if you have 12 small pistons goin up and down really fast, compared to 8 very large pistons about the size of a coffee mug each. which engine will be smoother? the big block v8 will be ruff as hell. that is why ferrari never went that route nor anyother major car manufacturer in the world. also generally those v8's doens't like to be reved as high as compared to a twin cam 4 valve per head engine. that motor might have a hemi head. but the hemi only maximizes air flow for a engine that uses 2 valves per head. thats as best as it gets for a pushrod motor. but when yoru comparing the CFM of a 4 valve per cylinder to a 2 valve. even with a hemi. the 4 valver will out flow the v8. plus the v12 will not have that crazy idle surge at idle cusae the cams will not try to stall the motor out. the v1 2 is alot more versitle of a motor in road racing. you try reving that big block and keep it near redline for the same amount of time as you do with a ferrari. the v8 might be strong enough to hold it self together for a short 1/4 mile pass at WOT. but in road racing your always near or at WOT near redline. thats F1 technology for you. also about the porsche. the GT2 will kill the turbo on the end cause its got less power train lose and weights a whole lot less. its almost better tuned in the suspension department and is more of a drivers car. while the turbo is for handling pussys. the GT2 takes real skills to drive. the end results is a car that is much faster in road racing if driven right.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 10-21-2003, 08:57 PM
total false hood.
big disp. big piston motors don't HAVE TO run rough to make big power.
thanks for the back up on the GT2 as well...
Old 10-21-2003, 09:02 PM
Originally Posted by flylwsi
total false hood.
of course the main rule of how smooth engine runs depends on the degrees of the V in the engine and the firing degrees along with the number of cylinders. the V8 is theoricaly suspose to be very smooth. however, given the sheer size of hte piston of a big block motor. ( about size of a coffee mug) as compared to a smaller displacement v8 lets say the 3.6 from a modena then the modena will be alot quieter and less ruff compared to a standard small block v8. so yes a large v8 does run ruffer then a v12 to a certain extent.
94 Acura NSX
Best E.T. 13.559
Old 10-21-2003, 09:16 PM
the ferrari doesn't have to run smooth either...
it's all about how the motor is designed...
you could build a big block that runs smooth. it's all about how you build it.
balance it, knife edge everything, and you'll run smooth, even with big power and big everything.
you can definitely get a very smooth running big block or big v8.
it'll run "rough" b/c of the way it's mounted in the car. old cars had inferior engine mounts compared to new cars like the ferrari. of course it won't run as "smooth".
but compare that to the 427 in the new saleen s7. it's still a pushrod motor, and it's big. but it runs smooth.
or the 8.1L motors in the new chevy trucks, which run smooth, but are huge. or the viper motors. or...
it's not the motor, it's how you feel that it runs "rough".
and a race motor without a dampener will run roughly/shaky in the car. that's why they put dampeners on cars.
you can't say that simply b/c the motor is big cubes, big cylinders, it's gonna run rough.
Old 10-21-2003, 09:26 PM
i wouldn't exactly call a viper engine as being smooth. that is goin alittle too extreme here. but since i've never experienced it first hand i cannot have any input. however the only inputs i can say is that from magazine articles. and they never praised that v10 for being smooth. even for its size. they could've atleast said that " the motor is smooth for its size" but i've never seen that writen at all. of course the nature of that motor is to be raw and to be and sound powerful. i wouldn't exactly call a camaro or firebird smooth either. even the modern ones. but i do see what your tryin to say. bottom line if both engines are built the same. the exact same manufacturing process. if two engines are built identically but one is considerably larger then the other. the smaller one will be smoother.
edit: i just read what i wrote. what i said sorta makes sence and sorta doesn't. ahhhh forget it. i guess this arguement can go on just like the other age old argument "what causes torque steer?" one camp said its the delayed reaction of the longer drive shaft. the other camp says its becuase the CV joint can't work as efficent in a steeper angle. so one tends to be alittle slower then the other.
94 Acura NSX
Best E.T. 13.559
Old 10-21-2003, 09:49 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
WHAT?
Do you SERIOUSLY equate more cylinders to more displacement, and displacement to efficiency?
Formula One cars have 3-liters of displacement, have V10's, and make 900+ HP. Are they inefficient?
I suggest you look up the differences between an oversquare and an undersquare engine, so you may qualify your statements better, at least in this issue.
2002_Nissan_Maxima_6-speed
Old 10-21-2003, 10:10 PM
i have.
it's not big and lumpy and shaking the car.
it depends on what a "rough" engine is in your eyes.
just b/c it has a rough sound doesn't mean it runs rough.
are we talking about vibrating the car, or sounding rough?
again, it's still about the location of the engine and how it's attached.
Old 10-21-2003, 10:13 PM
carrrnuttt's Avatar
Different methods to achieve the same thing. Engine power can be equated to fuel and air. The more of it you can combust within a given period of time, the more potential for power you have.
The big blocks achieve it with huge, pistons with long strokes that suck more air in...so that more fuel may be burnt. Oh, and they have more pistons...usually 8, 10, sometimes 16 (Cadillac).
Small, 4-cylinder motors achieve some semblance of high-HP, like in the S2000, by having ungodly RPMs, which also burns more air/fuel within a a given time. They also utilize turbos, which in a way artificially enhances their displacement, as they draw in atmosphere a motor twice or three times their displacement and cylinders.
Ferraris have gotten their HP by combining small-motor, and big-motor tricks. Their motors have fairly high RPM limits, but they also combine this with having more cylinders.
Smoothness of the motor has nothing to do with it's size...that's all in manufacturing. Efficiency has everything to do with how well any of these motors can translate the air/fuel combustion into mechanical movement of the engine's moving parts...that's all in the design.
Old 10-21-2003, 10:31 PM
heh when i say ruff. i was reffering to the sound.
94 Acura NSX
Best E.T. 13.559
Old 10-22-2003, 10:05 PM
do me a favor then...
go to www.corsaperf.com , go to the automotive side, and listen to their clips of the viper exhaust.
it's really not that "rough" sounding, and the corvette system screams at high rpms, especially with the titanium system on it.
and i wouldn't classify either as rough...
Old 10-22-2003, 10:18 PM
i must say that vette does sound mighty sweet. and so does that viper. i therefore stand corrected.
94 Acura NSX
Best E.T. 13.559
Old 10-26-2003, 01:17 PM
thanks....
Old 10-27-2003, 11:33 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Re: Re: Re: Re: North America's fastest production cars
Originally Posted by carrrnuttt
WHAT?
do you not see what im doing? i was playing devils advocate to get the conversation going. i usually post on g2ic (Generation 2 Integra Club) because the members are a lot more active in their posting. on here theres usually huge delays between replies, i was saying something that i knew would set some people off to boost the activity, at least in this thread. i KNOW the gt2 far surpasses the turbo in handling, i KNOW displacement per cylinder is not the equation for efficiency.
Old 10-27-2003, 08:40 PM
thats what i was thinkin casue i remembered you knowing more then that. but then you were talkin like a ricer all of the sudden. so i'm like huh? is this the same person that i remember?
94 Acura NSX
Best E.T. 13.559
