| Off-Topic Talk about anything other than cars. |
#16
Also dont confuse double-clutching with Power-shifting....
Double-clutching is basically just for shifting when coming out of a turn. You could move the shifter to neutral and then back into the same gear, but the main point is to try to match the trans speed with the engine speed, such as when you downshift from 3rd to 2nd, you push the clutch in, shift to 2nd, give it some gas to put the rpms up a little higher than they were in 3rd, and you have a nice smooth ride. This is a better idea than downshifting and just giving it a little bit of gas, so that the trans starts "dragging" to get you up to speed/rpms. Power shifting is when you keep the gas about the same when you press the clutch down, shifting, and then popping the clutch and flooring the gas. This is not only used in downshifting, but for going from 1-2, 2-3, 3-4, 4-5. The reason for this is to keep the RPMs in the engine's powerband, so that all the horsepower is being used.
91 Mitsu Eclipse - boostin 16psi(finally) look out hOnDuHz. |
#17
Thats not double-clutching either , thats rev matching. I already explained D-C'ing earlier , maybe you should read it...........
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap. '03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
#18
Power shifting is shifting with no clutch. You shift the tranny "under power" hence the name. Keeping the gas floored while shifting with the clutch is called speed shifting. Everyone screws this up, but this is the way it is. Powershifting is done only on tranny that can take (dog box typically) and speed shifting's only real benefit is on turbo cars, its a fine way to keep the turbo spooled. There is no lag if boost never falls
None of this has anything to do with keeping the engine in its power band. That can only be done by gear selection. No matter what you do with the clutch in, once you let it out the rpm is determined solely by the wheel speed of the car and the gear ratio you are in. Its a direct mechanical link. Many people are confused by this concept.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#19
#20
#21
damm rockin wrx u know ur shit. lol
#22
Even with a different type of shift mechanism, I still done think I would be comfortable power shifting a DSM tranny. The hub and slider break enough as it is, and the brass synchros are small... But that is a conributing factor for sure.
#23
#24
Xj...you're right
--When double clutching....you increase rpm when downshifting and let the rpm drop while upshifting |
