Go Back   Automotive Forums Car Chat > Cars in General
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-02-2002, 05:30 PM
darklight darklight is offline
that is as long as your not racing or something
  #17
Old 04-02-2002, 07:39 PM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
true, bigger is better, but there is such a thing as too big... huge alloys will mess up the car's lines and screw with the proportions... and as i said you had better fill the gaps with huge discs or the car will look ridiculous
  #18
Old 04-03-2002, 10:25 PM
banchi105 banchi105 is offline
Banned
Send a message via AIM to banchi105 Send a message via Yahoo to banchi105
It really depends on the car
but im am greatly against over-the top rimz like 20's on a small car
it looks so freaking stupid :smoka:
  #19
Old 04-04-2002, 01:45 PM
crayzayjay's Avatar
CFA
you said it
  #20
Old 05-28-2002, 11:22 AM
Tom_S8's Avatar
Tom_S8 Tom_S8 is offline
Send a message via AIM to Tom_S8
i had 18" stock on my audi...
anyway bigger rims are almost always better... but in bad weather they're worse (traction issues , yes , actually wide tires are supposed to give you better traction , and they do , but on wet it's the other way round) , on wide tires you have worse acceleration and top speed due to drag and weight , but then braking improves (the more rubber contacting the road , the better) , grip improves (if the tires are in good condition ) , stability improves , but in ruts the stability is f*cked up , anyway you have to calculate wheel + tire height to make sure it's the same or almost the same as stock... be sure that tires don't scratch the wheel arches (it happens , especially during turning wheels , when you choose rims and tires combination to big for your car)... if you run on big rims and wide tires you better have a set of smaller rims with narrower tires for witner , because big rims , and wide low profile tires would give you only problems if you have cold winters , if you have snow during the winter , then extra set of rims plus winter tires is a must... Don't go over the line... And big rims and wide tires should be for safety not looks , so don't cross the line... Anyway it's up to you , and there are also other things , like on low profile tires , when you hit a pot hole then you're more likely to blow your tire or damage your rim... also high performance tires and big rims are very expensive , and they give you stiffer ride and less comfort... but when you've got a fast car , especially if it's noticeably faster then stock car , you should first do the wheels and suspension upgrades , then power.... also make sure brakes are in good shape (if you're car is way more powerful than stock , then you should also think about some aftermarket stuff... like a DOT5 brake fluid , or some sport pads... if you're car is really over the top , very powerful and you drive fast then you should also think about new brake rotors and calipers...) .... ok enough of this crap
  #21
Old 06-05-2002, 11:26 PM
Steel's Avatar
Steel Steel is offline
actaully 10" rims are pretty big....for a truck. i have something like 12 or 14's... Except i have 31 inch tires so keep taht in mind
Old 06-23-2002, 04:58 PM
|Banchi1O5|'s Avatar
|Banchi1O5| |Banchi1O5| is offline
Send a message via AIM to |Banchi1O5| Send a message via Yahoo to |Banchi1O5|
take a look at a prowler
it rear rims are 21" or 22's i believe but they do look good on it.
really just depends on you car and the way it was styled
Reefer Does Me
  #23
Old 08-10-2002, 03:22 PM
gto_merah's Avatar
gto_merah gto_merah is offline
Send a message via AIM to gto_merah
We Indonesians think NOTHING is too big!
Try out this url: http://www.permaisuri.com, then click on Autoshow. Most of these cars are real cars in Indonesia! Brand-new BMW 745 with 22"! Toyota Harrier with 21"! 3-series with 19"! Galants with 19"! Trust me, no such thing as TOO BIG!
1995 Mitsubishi GTO SR
* 6G72 DOHC, 222 hp stock, ??? hp now
* 5-speed manual, sticky 1st gear mod
* Removed resonator bottle
* K&N FIPK
* Straight pipe between cat and stock dual exhaust
* 3" hi-flo cat
* 18x9 Speedy Baltics, +40mm offset
* 225/40 Pirelli PZero fronts
* 245/40 Dunlop SP9000 rears
* 400g weighted RAZO shifter
* "4-wheeling" on stock suspension mod
  #24
Old 08-10-2002, 04:52 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
18's are the biggest I would get. I'll most likely be replacing my 16's with 17's.
  #25
Old 09-01-2002, 12:28 PM
crayzayjay's Avatar
CFA
Actually, wheel arches are getting bigger. Sounds stupid i know, but have you seen how big they are on mk4 Golfs???
Example: 993 TT, those 18inch alloys looked stunning and more importantly big, on a 911
Today, 18inch alloys on a 330Ci Sport don't look that big, you'd need 19inchers to get the same effect as on the 993.... A few years you could only get 18inch wheels on some cars, today the amount of cars that offer 18inch alloys is much greater
  #26
Old 10-29-2003, 09:15 PM
24boxchevy 24boxchevy is offline
24s or biger
  #27
Old 10-30-2003, 07:06 AM
crayzayjay's Avatar
CFA
Re: rims--how big is too big?
This thread was dead. Thanks for resurrecting it with your enlightening post
Brake drums too small or shoes too big? jsinton Galant 1 10-27-2004 08:52 AM
rim size....too big? just right? fc82703uk Neon | Plymouth Neon 7 07-06-2004 08:00 PM
How big is too big exp20thcen SC/SL/SW 2 01-10-2004 12:09 AM
Too small...Too big???? MXrider22 Forced Induction 0 10-05-2003 10:45 PM
Too low - Too big? Tom Cimo Accord/TSX/Accord Hybrid 2 08-12-2003 01:29 AM
Closed Thread
