Old 07-27-2003, 10:56 PM
XixGenuinexiX XixGenuinexiX is offline
whats a header?? and what does it do?
does it give a good hp gain?
Old 07-27-2003, 10:58 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
header is where the exhaust gases exit through...
yeah....you'd see maybe 2-4 hp increase with that header over a stock header.....
but the header from the D16(civic motor) will not bolt up to the B18C1 or B16....so you'd have to buy one...
ITR inside
Old 07-27-2003, 11:01 PM
what type of header would i have to buy???
and will the stock tires be ok for the new engine?
and about how much for breaks if you know?
oh another thing is the gsr engine OBD1 or OBD2
Old 07-27-2003, 11:03 PM
97gsr's Avatar
any b-series header will work
stock tires will be fine.... probably 14 inches....i'd look for some 15 inchers......
and yeah...i have no idea about the brakes....
94-95 gsr is obd1
96+ is obd2
ITR inside
Old 07-27-2003, 11:08 PM
so i'd have to get a 96++ gser engine right?
do those still cost around 3k?
cause doesn't the 96-00 civics have odb2
Old 07-27-2003, 11:19 PM
97gsr's Avatar
man....i'm gonna be honest with ya... i know NOTHING about civics....
so i cant answer those.......sorry.....
ITR inside
Old 07-27-2003, 11:44 PM
my bad my internet stopped working for a while
Old 07-28-2003, 07:27 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
97gsr pretty much covered it all. As far as what engine in what Civic, it goes like this. The engine has to be of the same year or newer for legal purposes and does'nt matter if it's a Teg or Civic motor. Yes, not having to mess with OBD conversions saves alot of hassels so if you get the right engine, by legal standards, there should be no conversion needed. Since you're a n00b at this I will assume that you want to do this as cost effective as possible so forget about most of the brand names 97gsr posted seeing as they are some of the best parts out there. There are cheaper parts performance parts. As long as you get the car and the engine, high priced, high quality parts can wait.
Old 07-29-2003, 12:39 AM
So for the new engine, i won't need a better exhaust system or anything?? what would i need to get with the new engine so that everything runs smoothly? and how can i tell what year the engine was?
Old 07-29-2003, 02:52 PM
B16EJ1's Avatar
There are guys that like the JDM performance but not the loud noise or look of most Honda's today. I know a guy that has a JDM ITR motor and everything on the car is OEM JDM except for the fact that it's not RHD. He modified the OEM exhaust flange to mat up to a JDM ITR cat. This does not damage the motor but simply restrict flow and hp.
There are three round seals w/ numbers on them on the head just above the exhaust manifold. The first seal has the last two numbers of the year of production. I'll try and find a pic I posted a while back.
Old 07-29-2003, 10:25 PM
So i won't need a new exhaust system for my 96-00 civic sedan?
Old 07-29-2003, 11:01 PM
B16EJ1's Avatar
Needed??? No. MOdification to match evrything together??? Yes.
Old 07-29-2003, 11:02 PM
so the b18 i'm thinking about getting isn't vtec right? is there anyway i can make it vtec?
Old 07-30-2003, 06:44 PM
93DC2 93DC2 is offline
sorry man. gotta swap out your engine. or do the frankenstein thing. it would be sweet for you if you lived here in japan man. $3000 for a '93 vtec integra. cheap parts
Old 07-30-2003, 10:37 PM
if i do a b18 swap will i still have air condition if not i'm thinking about a b16
newbie need help onastick '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-07-2002 02:35 PM
newbie needs help cue-2-8 Sentra | 200SX (USDM FWD) 1 08-19-2002 12:49 PM
honda newbie needs help sinfestboy Integra 3 07-16-2002 07:14 PM
Newbie needs help..... dan_nz_man Audio/Security 1 03-27-2002 05:17 AM
