Old 08-03-2012, 11:22 PM
Walis Walis is offline
Re: 2000 Ford Taurus - HEAVY JERKING
pardon my lack of knowledge but where's the brake booster located and what does it look like?
thank you.
Old 08-04-2012, 07:50 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The brake booster is the large drum like thing between the brake master cylinder (with the brake fluid reservoir) and the brake pedal assembly. It will be under the hood and the master cylinder is mounted to it. You can do a Google image search for "brake booster" to get a better idea what it looks like.
I'm curious where this is going though as I don't see how a brake booster issue could cause brakes to not retract. It could cause a hard pedal and it could cause a misfire due to vacuum leak, but stuck brakes?
-Rod
Old 08-04-2012, 09:19 AM
plymouthsrock plymouthsrock is offline
As you know, a brake booster has vacuum applied to both sides of a diaphragm, and when the pedal is applied, it opens a valve that vents the vacuum on one side, giving the asist. If that valve is sticky or doesn't close fully, it can apply the brakes slightly. Not a common failure, but did happen in the CV/GM/TC models in the 90's.
Old 08-17-2014, 10:38 PM
BeaJean BeaJean is offline
It sounds like the car needs some new rotors.
Old 08-17-2014, 11:08 PM
shorod's Avatar
SHO No Mo
Since the jerking happens under acceleration, not braking, the issue is not likely to be brake rotors. When brake rotors have too much runout the jerking happens when applying the brakes, not when accelerating.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
65comet (08-19-2014)
  #21
Old 08-19-2014, 04:19 PM
65comet's Avatar
65comet 65comet is offline
Rod,
I thought you could use a Thanks for your patience with the newbies. He only has 3 posts and is picking a two year old entry to throw 2 cents at it that clearly don't apply. Keep dispensing your wisdom with kindness.
Randy
The Following User Says Thank You to 65comet For This Useful Post:
shorod (08-19-2014)
  #22
Old 08-19-2014, 10:18 PM
shorod's Avatar
SHO No Mo
He's also from Iowa so I will cut him some slack.
-Rod
2000 Ford taurus jerking above 65mph taylor021 Taurus | Taurus Wagon 7 08-17-2010 12:12 AM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 05:40 PM
will the transmission in a 95 taurus work in a 2000 ford taurus bj_the_king Taurus | Taurus Wagon 1 11-10-2006 07:49 PM
2000 ford Taurus Keyless Entry MikePercak Taurus | Taurus Wagon 4 06-19-2004 10:35 AM
2000 Ford Taurus SE SVG-Engine Block Heater SlimD Taurus | Taurus Wagon 0 12-07-2003 07:48 PM
