Old 04-29-2004, 07:17 AM
geofroley geofroley is offline
Send a message via AIM to geofroley
Re: Technique to lower the ride height
Originally Posted by SteveK2003
To make lowering the chassis even easier, if slightly less to-scale, try this:
Instead of cutting and swapping and regluing the suspension arms, simply extend the 'pin' at the bottom of the steering spindle, the one that meets the lower suspension arm and allows it to pivot. This will let the spindle, and thus the wheel, raise up into the fender when you trim the spring, but it will still keep everything lined up with the lower suspension. Simply take up the slack with some small washers or spacers made of styrene, so the wheel doesn't droop when you pick the model up.
This method shouldn't look too out of place, if at all, for most cars and anything buy a radical drop.
Got a pic?
Old 01-04-2007, 09:45 AM
Mister_S13's Avatar
Mister_S13 Mister_S13 is offline
Re: HOW TO lower the ride height
nice, but an easier way to get the uspension arms up higher is to heat the joints above a candle till soft, then just bend them upwards,much stronger, but good technique...so what about the steering at the front?
Old 01-04-2007, 07:55 PM
rsxse240 rsxse240 is offline
I say just build a complete working suspension! haha, j/k
how about instead of cutting ALL THE WAY through the lower control arm, only cut halfway, then it will bend easily, then bring it up to your spindle and fill the gap in the LCA with epoxy, or styrene. this is how I have done it for YEARS, and haven't had a working steering front end fall off yet. you will not lose any detail from the kit, and it all looks like it should be that way.
Old 01-04-2007, 08:35 PM
tonioseven's Avatar
That's the same way I do it as well.
